Datasheet VDRUS (Vishay) - 8
ManufacturerVishay
DescriptionVDR Metal Oxide Varistors Ultra Surge High Operating Temperature 125°C
Pages / Page15 / 8 — VDRUS Series. TAPED VERSION WITH KINKED LEADS. TAPING DATA. …
File Format / SizePDF / 227 Kb
VDRUS Series. TAPED VERSION WITH KINKED LEADS. TAPING DATA. DIMENSIONS/TOLERANCE. SYMBOL. PARAMETER. VDRUS07. VDRUS10. VDRUS14. Notes
VDRUS Series TAPED VERSION WITH KINKED LEADS TAPING DATA DIMENSIONS/TOLERANCE SYMBOL PARAMETER VDRUS07 VDRUS10 VDRUS14 Notes
VDRUS Series
www.vishay.com Vishay BCcomponents
 (only for VDRUS07) (only for VDRUS10 and VDRUS14)
P P T T D
Δ Δ
p
Δ
p
Δ
h
Δ
h D p
Δ
p
Δ
h
Δ
h A A 0 0 d W d 2 F W2 H L 0 W W W 0 1 H W W W 0 0 1 P P D F P P D 0 1 0 1 0 0 T1 t T1 t TAPING DATA
(based on IEC 60286-2)
V  300 V 14.5 A max. Max. mounting height 11.0 19.0 V > 300 V 15.5 V  320 V 16.5 21.0 A0 max. Max. mounting height 13.0 V > 320 V 17.0 21.5 V  320 V 12.0 16.0 D max. Max. body diameter 9.0 V > 320 V 12.5 16.5 d Lead wire diameter 0.6 ± 0.05 0.8 ± 0.05 F Lead to lead distance (1) 5.0 + 0.8/- 0.2 7.5 ± 0.8 H Distance component to tape center (2) 20.0 + 2.0/- 0.0 18.0 + 2.0/- 0.0 H0 Lead wire clinch height 16.0 or 18.25 ± 0.5 P Pitch of components on tape 12.7 ± 1.0 25.4 ± 1.0 T Total thickness See Electrical Data table
Notes
(1) Guaranteed between component and tape (2) For VDRUS14X510xSE and VDRUS14X550xSE: H = 20 mm ± 1 mm Revision: 18-Jun-2019
8
Document Number: 29185 For technical questions, contact: nlr@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
