Datasheet AD810-EP (Analog Devices) - 3
DescriptionLow Power Video Op Amp with Disable
Pages / Page8 / 3 — Enhanced Product. AD810-EP. SPECIFICATIONS. Table 1. Parameter. Test …
File Format / SizePDF / 163 Kb
Enhanced Product. AD810-EP. SPECIFICATIONS. Table 1. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Enhanced Product AD810-EP SPECIFICATIONS Table 1 Parameter Test Conditions/Comments Min Typ Max Unit
link to page 4
TA = 25°C, supply voltage (VS) = ±15 V dc, load resistance (RL) = 150 Ω, unless otherwise noted.
Table 1. Parameter Test Conditions/Comments Min Typ Max Unit
DYNAMIC PERFORMANCE −3 dB Bandwidth G = +2, feedback resistor (RF) = 715 Ω, VS = ±5 V 40 50 MHz G = +2, RF = 715 Ω, VS = ±15 V 55 75 MHz G = +1, RF = 1000 Ω, VS = ±15 V 40 80 MHz G = +10, RF = 270 Ω, VS = ±15 V 50 65 MHz 0.1 dB Bandwidth G = +2, RF = 715 Ω, VS = ±5 V 13 22 MHz G = +2, RF = 715 Ω, VS = ±15 V 15 30 MHz Full Power Bandwidth Output voltage (VOUT) = 20 V p-p RL = 400 Ω 8 16 MHz Slew Rate1 RL = 150 Ω, VS = ±5 V 175 350 V/µs RL = 400 Ω, VS = ±15 V 500 1000 V/µs Settling Time to 0.1% 10 V step, G = −1 50 ns Settling Time to 0.01% 10 V step, G = −1 125 ns Differential Gain f = 3.58 MHz, VS = ±15 V 0.02 0.05 % f = 3.58 MHz, VS = ±5 V 0.04 0.07 % Differential Phase f = 3.58 MHz, VS = ±15 V 0.04 0.07 Degrees f = 3.58 MHz, VS = ±5 V 0.045 0.08 Degrees Total Harmonic Distortion f = 10 MHz, VOUT = 2 V p-p RL = 400 Ω, G = +2 −61 dBc INPUT OFFSET VOLTAGE VS = ±5 V and ±15 V 1.5 6 mV TMIN to TMAX, VS = ±5 V and ±15 V 4 15 mV Offset Voltage Drift 15 µV/°C INPUT BIAS CURRENT Negative Input TMIN to TMAX, VS = ±5 V and ±15 V 0.8 5 µA Positive Input TMIN to TMAX, VS = ±5 V and ±15 V 2 10 µA OPEN-LOOP TRANSRESISTANCE TMIN to TMAX VOUT = ±10 V, RL = 400 Ω, VS = ±15 V 1.0 3.5 MΩ VOUT = ±2.5 V, RL = 100 Ω, VS = ±5 V 0.2 1.0 MΩ OPEN-LOOP DC VOLTAGE GAIN TMIN to TMAX VOUT = ±10 V, RL = 400 Ω, VS = ±15 V 80 100 dB VOUT = ±2.5 V, RL = 100 Ω, VS = ±5 V 72 88 dB COMMON-MODE REJECTION TMIN to TMAX Offset Voltage (VOS) Common-mode voltage (VCM) = ±12 V, VS = ±15 V 56 64 dB VCM = ±2.5 V, VS = ±5 V 50 60 dB Input Bias Current TMIN to TMAX, VS = ±5 V and ±15 V −0.4 0.1 +0.4 µA/V POWER SUPPLY REJECTION VOS TMIN to TMAX, VS = ±4.5 V to ±18 V 60 72 dB Input Bias Current TMIN to TMAX −0.3 0.05 +0.3 µA/V INPUT VOLTAGE NOISE f = 1 kHz, VS = ±5 V and ±15 V 2.9 nV/√Hz INPUT CURRENT NOISE Negative input current (–IIN), 13 pA/√Hz f = 1 kHz, VS = ±5 V and ±15 V Positive input current (+IIN), f = 1 kHz, VS = ±5 V and ±15 V 1.5 pA/√Hz INPUT COMMON-MODE VOLTAGE VS = ±5 V ±2.5 ±3.0 V RANGE VS = ±15 V ±12 ±13 V Rev. 0 | Page 3 of 8 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
