Datasheet ADA4625-1, ADA4625-2 (Analog Devices) - 3
Description36 V, 18 MHz, Low Noise, Fast Settling Single Supply, RRO, JFET Op Amp
Pages / Page35 / 3 — Data Sheet. ADA4625-1. /ADA4625-2. SPECIFICATIONS ELECTRICAL …
Data Sheet. ADA4625-1. /ADA4625-2. SPECIFICATIONS ELECTRICAL CHARACTERISTICS—±18 V OPERATION. Table 2. Parameter. Symbol
Data Sheet ADA4625-1 /ADA4625-2 SPECIFICATIONS ELECTRICAL CHARACTERISTICS—±18 V OPERATION Table 2 Parameter Symbol
Supply voltage (VSY) = ±18 V, common-mode voltage (VCM) = output voltage (VOUT) = 0 V, TA = 25°C, unless otherwise noted.
Table 2. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS ADA4625-1 ±15 ±80 µV ADA4625-2 ±100 µV −40°C < TA < +125°C ±250 µV Offset Voltage Drift TCVOS −40°C < TA < +85°C ±0.2 ±1.2 µV/°C −40°C < TA < +125°C ±0.5 ±2.1 µV/°C Input Bias Current IB ±15 ±75 pA ADA4625-1, −40°C < TA < +125°C ±5.5 nA ADA4625-2, −40°C < TA < +125°C ±7 nA Input Offset Current IOS ±2 ±50 pA ADA4625-1, −40°C < TA < +125°C ±0.4 nA ADA4625-2, −40°C < TA < +125°C ±0.7 nA Input Voltage Range IVR −18.2 +14.5 V Common-Mode Rejection Ratio CMRR VCM = −18.2 V to +14.5 V 97 115 dB −40°C < TA < +125°C 94 dB VCM = −18.2 V to +12 V 115 130 dB −40°C < TA < +125°C 110 dB Large Signal Voltage Gain AVO Load resistance (RL) = 2 kΩ, VOUT = −17.5 V to 140 150 dB +17.5 V −40°C < TA < +125°C 135 dB RL = 600 Ω, VOUT = −15 V to +15 V 130 135 dB ADA4625-1, −40°C < TA < +125°C 115 dB ADA4625-2, −40°C < TA < +125°C 100 dB Input Capacitance Differential Mode CDM ADA4625-1 8.6 pF ADA4625-2 13.8 pF Common Mode CCM ADA4625-1 11.3 pF ADA4625-2 13.3 pF Input Resistance RDM Differential mode 1012 Ω RCM Common mode, VCM from −18 V to +12 V 1012 Ω OUTPUT CHARACTERISTICS Output Voltage High VOH RL = 2 kΩ 17.65 17.72 V −40°C < TA < +125°C 17.5 V RL = 600 Ω 17.0 17.28 V −40°C < TA < +125°C 16.75 V Output Voltage Low VOL RL = 2 kΩ −17.74 −17.70 V −40°C < TA < +125°C −17.5 V RL = 600 Ω −17.4 −17.0 V −40°C < TA < +125°C −16.85 V Output Current IOUT Dropout voltage (VDROPOUT) < 1 V ±33 mA Short-Circuit Current ISC ±46 mA Closed-Loop Output Impedance ZOUT f = 1 MHz, closed-loop gain (AV) = +1 2 Ω AV = +10 18 Ω AV = +100 29 Ω POWER SUPPLY Power Supply Rejection Ratio PSRR VSY = ±5 V to ±18 V 105 120 dB −40°C < TA < +125°C 102 dB Supply Current per Amplifier ISY VOUT = 0 V 4.0 4.5 mA −40°C < TA < +125°C 5 mA Rev. A | Page 3 of 35 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—±18 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT AND GAIN STAGES OUTPUT STAGE NO PHASE INVERSION SUPPLY CURRENT APPLICATIONS INFORMATION ACTIVE LOOP FILTER FOR PHASE-LOCKED LOOPS (PLLS) PLL Basic Loop Filter ADA4625-1 ADVANTAGES AND DESIGN EXAMPLE TRANSIMPEDANCE AMPLIFIER Design Example DAC OUTPUT DRIVER RECOMMENDED POWER SOLUTION INPUT OVERVOLTAGE PROTECTION DRIVING CAPACITIVE LOADS THERMAL MANAGEMENT TYPICAL APPLICATIONS OUTLINE DIMENSIONS ORDERING GUIDE
