Datasheet IRF9510S, SiHF9510S (Vishay) - 2
ManufacturerVishay
DescriptionPower MOSFET
Pages / Page9 / 2 — IRF9510S, SiHF9510S. THERMAL RESISTANCE RATINGS PARAMETER SYMBOL. TYP. …
File Format / SizePDF / 179 Kb
IRF9510S, SiHF9510S. THERMAL RESISTANCE RATINGS PARAMETER SYMBOL. TYP. MAX. UNIT. Note. SPECIFICATIONS. PARAMETER SYMBOL. TEST
IRF9510S, SiHF9510S THERMAL RESISTANCE RATINGS PARAMETER SYMBOL TYP MAX UNIT Note SPECIFICATIONS PARAMETER SYMBOL TEST
IRF9510S, SiHF9510S
Vishay Siliconix
THERMAL RESISTANCE RATINGS PARAMETER SYMBOL TYP. MAX. UNIT
Maximum Junction-to-Ambient RthJA - 62 Maximum Junction-to-Ambient °C/W (PCB Mount)a RthJA - 40 Maximum Junction-to-Case (Drain) RthJC - 3.5
Note
a. When mounted on 1" square PCB (FR-4 or G-10 material).
SPECIFICATIONS
(TJ = 25 °C, unless otherwise noted)
PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT Static
Drain-Source Breakdown Voltage VDS VGS = 0, ID = - 250 μA - 100 - - V VDS Temperature Coefficient VDS/TJ Reference to 25 °C, ID = - 1 mA - - 0.091 - V/°C Gate-Source Threshold Voltage VGS(th) VDS = VGS, ID = - 250 μA - 2.0 - - 4.0 V Gate-Source Leakage IGSS VGS = ± 20 V - - ± 100 nA VDS = - 100 V, VGS = 0 V - - - 100 Zero Gate Voltage Drain Current IDSS μA VDS = - 80 V, VGS = 0 V, TJ = 150 °C - - - 500 Drain-Source On-State Resistance RDS(on) VGS = - 10 V ID = - 2.4 Ab - - 1.2 Forward Transconductance gfs VDS = - 50 V, ID = - 2.4 Ab 1.0 - - S
Dynamic
Input Capacitance Ciss - 200 - VGS = 0 V, Output Capacitance Coss VDS = - 25 V, - 94 - pF f = 1.0 MHz, see fig. 5 Reverse Transfer Capacitance Crss - 18 - Total Gate Charge Qg - - 8.7 I Gate-Source Charge Qgs V D = - 4.0 A, VDS = - 80 V, GS = - 10 V - - 2.2 nC see fig. 6 and 13b Gate-Drain Charge Qgd - - 4.1 Turn-On Delay Time td(on) - 10 - Rise Time tr V - 27 - DD = - 50 V, ID = - 4.0 A, ns Rg = 24 , RD = 11 , see fig. 10b Turn-Off Delay Time td(off) - 15 - Fall Time tf - 17 - Between lead, D Internal Drain Inductance LD - 4.5 - 6 mm (0.25") from nH package and center of G Internal Source Inductance LS die contact - 7.5 - S
Drain-Source Body Diode Characteristics
MOSFET symbol Continuous Source-Drain Diode Current IS D - - - 4.0 showing the integral reverse A G Pulsed Diode Forward Currenta ISM p - n junction diode - - - 16 S Body Diode Voltage VSD TJ = 25 °C, IS = - 4.0 A, VGS = 0 Vb - - - 5.5 V Body Diode Reverse Recovery Time trr - 82 160 ns TJ = 25 °C, IF = - 4.0 A, dI/dt = 100 A/μsb Body Diode Reverse Recovery Charge Qrr - 0.15 0.30 μC Forward Turn-On Time ton Intrinsic turn-on time is negligible (turn-on is dominated by LS and LD)
Notes
a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11). b. Pulse width  300 μs; duty cycle  2 %. www.vishay.com Document Number: 91073 2 S11-1050-Rev. C, 30-May-11 This document is subject to change without notice. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
