Datasheet PZT2222A (ON Semiconductor) - 6
Manufacturer | ON Semiconductor |
Description | NPN Bipolar Transistor |
Pages / Page | 7 / 6 — SOT−223 (TO−261). GENERIC. MARKING DIAGRAM*. DOCUMENT NUMBER: … |
Revision | 11 |
File Format / Size | PDF / 176 Kb |
SOT−223 (TO−261). GENERIC. MARKING DIAGRAM*. DOCUMENT NUMBER: 98ASB42680B. DESCRIPTION:. PAGE 2 OF 2
SOT−223 (TO−261)
CASE 318E−04 ISSUE R DATE 02 OCT 2018 STYLE 1: STYLE 2: STYLE 3: STYLE 4: STYLE 5: PIN 1. BASE PIN 1. ANODE PIN 1. GATE PIN 1. SOURCE PIN 1. DRAIN 2. COLLECTOR 2. CATHODE 2. DRAIN 2. DRAIN 2. GATE 3. EMITTER 3. NC 3. SOURCE 3. GATE 3. SOURCE 4. COLLECTOR 4. CATHODE 4. DRAIN 4. DRAIN 4. GATE STYLE 6: STYLE 7: STYLE 8: STYLE 9: STYLE 10: PIN 1. RETURN PIN 1. ANODE 1 CANCELLED PIN 1. INPUT PIN 1. CATHODE 2. INPUT 2. CATHODE 2. GROUND 2. ANODE 3. OUTPUT 3. ANODE 2 3. LOGIC 3. GATE 4. INPUT 4. CATHODE 4. GROUND 4. ANODE STYLE 11: STYLE 12: STYLE 13: PIN 1. MT 1 PIN 1. INPUT PIN 1. GATE 2. MT 2 2. OUTPUT 2. COLLECTOR 3. GATE 3. NC 3. EMITTER 4. MT 2 4. OUTPUT 4. COLLECTOR
GENERIC MARKING DIAGRAM*
AYW XXXXXG G 1 A = Assembly Location Y = Year W = Work Week XXXXX = Specific Device Code G = Pb−Free Package (Note: Microdot may be in either location) *This information is generic. Please refer to device data sheet for actual part marking. Pb−Free indicator, “G” or microdot “G”, may or may not be present. Some products may not follow the Generic Marking.
Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red.
DESCRIPTION: SOT−223 (TO−261) PAGE 2 OF 2
ON Semiconductor and are trademarks of Semiconductor Components Industries, LLC dba ON Semiconductor or its subsidiaries in the United States and/or other countries. ON Semiconductor reserves the right to make changes without further notice to any products herein. ON Semiconductor makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does ON Semiconductor assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. ON Semiconductor does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 2018 www.onsemi.com
