Datasheet AD7766-KGD (Analog Devices) - 4
Description24-Bit, 8.5 mW, 109 dB, 128 kSPS/64 kSPS/32 kSPS ADCs
Pages / Page11 / 4 — AD7766-2-KGD. Known Good Die. Parameter. Test Conditions/Comments. Min. …
File Format / SizePDF / 242 Kb
AD7766-2-KGD. Known Good Die. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
AD7766-2-KGD Known Good Die Parameter Test Conditions/Comments Min Typ Max Unit
POWER REQUIREMENTS AVDD ±5% 2.5 V DVDD ±5% 2.5 V VDRIVE 1.7 2.5 3.6 V CURRENT SPECIFICATIONS MCLK = 1.024 MHz Operational Current 32 kHz output data rate Analog Quiescent Current (AIDD) 1.3 1.5 mA Digital Quiescent Current (DIDD) 1.37 1.86 mA Reference Current (IREF) 0.35 0.425 mA Static Current with MCLK Stopped AIDD 0.9 1 mA DIDD 1 93 µA Power-Down Mode Current AIDD 0.1 6 µA DIDD 1 93 µA POWER DISSIPATION MCLK = 1.024 MHz Operational Power 32 kHz output data rate 8.5 10.5 mW Rev. 0 | Page 4 of 11 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM RELATED DEVICES TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
