Datasheet AD7766-KGD (Analog Devices) - 7
Description | 24-Bit, 8.5 mW, 109 dB, 128 kSPS/64 kSPS/32 kSPS ADCs |
Pages / Page | 11 / 7 — Known Good Die. AD7766-2-KGD. MCLK. DRDY (A). SDO (A). MSB (A). LSB (A) … |
File Format / Size | PDF / 242 Kb |
Known Good Die. AD7766-2-KGD. MCLK. DRDY (A). SDO (A). MSB (A). LSB (A) MSB (B). LSB (B) MSB (C). LSB (C). SCLK. t16. t17. MSB (B)
Known Good Die AD7766-2-KGD MCLK 1 DRDY (A) CS SDO (A) MSB (A) LSB (A) MSB (B) LSB (B) MSB (C) LSB (C) SCLK t16 t17
5 1 0
MSB (B) LSB (B) MSB (C) LSB (C) MSB (D) LSB (D)
6-
SDI (A) = SDO (B)
80 13 Figure 5. Daisy-Chain SDI Setup and Hold Timing
PART OUT OF POWER-DOWN FILTER RESET PART IN POWER-DOWN BEGINS SAMPLING MCLK (I) A B C D t t20 18 SYNC/PD (I) t t 19 21 DRDY (O) tSETTLING
05 0
SDO (O) VALID DATA INVALID DATA VALID DATA
6- 380 1 Figure 6. Reset, Synchronization, and Power-Down Timing Rev. 0 | Page 7 of 11 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM RELATED DEVICES TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
