Datasheet LTM2173-14 (Analog Devices) - 10
Description14-Bit, 80Msps Low Power Quad ADC
Pages / Page28 / 10 — TIMING DIAGRAMS. SPI Port Timing (Readback Mode). SPI Port Timing (Write …
File Format / SizePDF / 414 Kb
TIMING DIAGRAMS. SPI Port Timing (Readback Mode). SPI Port Timing (Write Mode)
TIMING DIAGRAMS SPI Port Timing (Readback Mode) SPI Port Timing (Write Mode)
LTM2173-14
tS tDS tDH tSCK tH CS SCK tDO SDI R/W A6 A5 A4 A3 A2 A1 A0 XX XX XX XX XX XX XX XX SDO D7 D6 D5 D4 D3 D2 D1 D0 HIGH IMPEDANCE
CS SCK SDI R/W A6 A5 A4 A3 A2 A1 A0 D7 D6 D5 D4 D3 D2 D1 D0 SDO 217314 TD08 HIGH IMPEDANCE Rev. A 10 For more information www.analog.com Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Converter Characteristics Analog Input Dynamic Accuracy Internal Reference Characteristics Digital Inputs And Outputs Power Requirements Timing Characteristics Timing Diagrams Pin Functions Pin Configuration Table Functional Block Diagram Applications Information Package Description Related Parts Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Converter Characteristics Analog Input Dynamic Accuracy Internal Reference Characteristics Digital Inputs And Outputs Power Requirements Timing Characteristics Timing Diagrams Typical Performance Characteristics Pin Functions Pin Configuration Table Functional Block Diagram Applications Information Converter Operation Analog Input Input Drive Circuits Digital Outputs Data Format Device Programming Modes Grounding and Bypassing Heat Transfer Package Description Revision History Typical Application Related Parts
