Datasheet ADW12001 (Analog Devices) - 4
DescriptionDual 14-Bit, 20/40/65 MSPS, 3 V Analog-to-Digital Converter
Pages / Page24 / 4 — ADW12001. 25°C. 115°C. Parameter. Temp. Min. Typ. Max. Unit
File Format / SizePDF / 678 Kb
ADW12001 25°C 115°C Parameter Temp Min Typ Max Unit
ADW12001 25°C 115°C Parameter Temp Min Typ Max Min Typ Max Unit
MATCHING CHARACTERISTICS Offset Error (Nonshared Reference Mode) 25°C ±0.19 ±1.56 ±0.25 ±1.74 % FSR Offset Error (Shared Reference Mode) 25°C ±0.19 ±1.56 ±0.25 ±1.74 % FSR Gain Error (Nonshared Reference Mode) 25°C ±0.07 ±1.43 ±0.07 ±1.47 % FSR Gain Error (Shared Reference Mode) 25°C ±0.01 ±0.06 ±0.01 ±0.10 % FSR 1 Gain error and gain temperature coefficients are based on the ADC only (with a fixed 1.0 V external reference). 2 Measured at the maximum clock rate with a low frequency sine wave input and approximately 5 pF loading on each output bit. 3 Input capacitance refers to the effective capacitance between one differential input pin and AVSS. Refer to Figure 1 f 8 or the equivalent analog input structure. 4 Measured with dc input at the maximum clock rate. 5 Standby power is measured with the CLK_A and CLK_B pins inactive (that is, set to AVDD or AGND). Rev. 0 | Page 4 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS Timing Diagram ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TERMINOLOGY TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ANALOG INPUT Differential Input Configurations Single-Ended Input Configuration CLOCK INPUT AND CONSIDERATIONS POWER DISSIPATION AND STANDBY MODE DIGITAL OUTPUTS TIMING DATA FORMAT VOLTAGE REFERENCE Internal Reference Connection External Reference Operation THERMAL CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
