Datasheet RH1021-7 (Analog Devices)
DescriptionPrecision 7V Reference
Pages / Page6 / 1 — DESCRIPTION. ABSOLUTE MAXIMUM RATINGS. (Note 10). BURN-IN CIRCUITS. PIN …
RevisionF
File Format / SizePDF / 555 Kb
DESCRIPTION. ABSOLUTE MAXIMUM RATINGS. (Note 10). BURN-IN CIRCUITS. PIN CONFIGURATION
Datasheet RH1021-7 Analog Devices, Revision: F
RH1021-7 Precision 7V Reference
DESCRIPTION ABSOLUTE MAXIMUM RATINGS (Note 10)
The RH1021-7 is a precision 7V reference with ultralow Input Voltage ...40V drift and noise, extremely good long-term stability and Input/Output Voltage Differential ..35V almost total immunity to input voltage variations. The Output to Ground Voltage reference output will source and sink up to 10mA. This (Shunt Mode Current Limit) ..10V reference can also be used as a shunt regulator (2-termi- Output Short-Circuit Duration nal Zener). Unique circuit design makes the RH1021-7 the VIN = 35V ..10 sec first IC reference to offer ultralow drift without the use of VIN ≤ 20V ... Indefinite high power on-chip heaters. Operating Temperature Range ... –55°C to 125°C Maximum Junction Temperature .. 150°C The wafer lots are processed to Linear Technology’s Storage Temperature Range .. –65°C to 150°C in-house Class S flow to yield circuits usable in stringent Lead Temperature (Soldering, 10 sec) ...300°C military applications. All registered trademarks and trademarks are the property of their respective owners.
BURN-IN CIRCUITS PIN CONFIGURATION
8 TOP VIEW 1 7 NC* 8 20V 2 RH1021-7 6 NC* 1 7 NC* 3 5 VIN 2 6 VOUT 4 NC* 3 5 NC* 4 –20V GND H PACKAGE 8-LEAD TO-5 METAL CAN *CONNECTED INTERNALLY, DO NOT CONNECT EXTERNAL CIRCUITRY TO THESE PINS. Rev F 1 Document Outline Description Absolute Maximum Ratings Burn-In Circuits Pin Configuration Order Information Table 1: Electrical Characteristics Table 1A: Electrical Characteristics Table 2: Electrical Test Requirements Total Dose Bias Circuit Revision History Typical Performance Characteristics
