Datasheet XC6237 (Torex) - 5
ManufacturerTorex
DescriptionUltra-Low Supply Current 0.6μA High Speed LDO Voltage Regulators
Pages / Page27 / 5 — XC6237. Series
XC6237. Series
XC6237 Series
XC6237
XC6237 Series
■ABSOLUTE MAXIMUM RATINGS Ta=25℃ PARAMETER SYMBOL RATINGS UNITS VIN Pin Voltage VIN -0.3~+6.5 V VOUT Pin Current IOUT 250(*1) mA VOUT Pin Voltage VOUT -0.3~VIN+0.3 or 6.5(*2) V CE Pin Voltage VCE -0.3~+6.5 V 100 USPQ-4B05 550 (40mm x 40mm Standard Board)(*3) 150 Power Dissipation SSOT-24 Pd 500 (40mm x 40mm Standard Board)(*3) mW 680 (JESD51-7 Board) (*3) 250 SOT-23 500 (40mm x 40mm Standard Board)(*3) Operating Ambient Temperature Topr -40~+105 ℃ Storage Temperature Tstg -55~+125 ℃ All voltages are described based on the VSS. (*1) Please use within the range of IOUT≦Pd / (VIN-VOUT) (*2) The maximum rating corresponds to the lowest value between VIN+0.3V or +6.5V. (*3) The power dissipation figure shown is PCB mounted and is for reference only. The mounting condition is please refer to PACKAGING INFORMATION. 5/27 Document Outline XC6237 (2) XC6237_ETR03100-001 XC6237 XC6237_ETR03100-001
