Datasheet ADL5331 (Analog Devices) - 6
Description1 MHz to 1.2 GHz VGA with 30 dB Gain Control Range
Pages / Page15 / 6 — ADL5331. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. dB). N (. R (. …
File Format / SizePDF / 711 Kb
ADL5331. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. dB). N (. R (. AI G. PE (m. –1 ERRO. O SL 10. –10. –15. –20. 0.1. 0.3. 0.5. 0.7. 0.9. 1.1. 1.3. 100
ADL5331 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS dB) N ( R ( AI G PE (m –1 ERRO O SL 10 –10 –15 –20 0.1 0.3 0.5 0.7 0.9 1.1 1.3 100
VS = 5 V; TA = 25°C; M/A-COM ETC1-1-13 1:1 balun at input and output for single-ended 50 Ω match.
20 4 30 15 3 25 10 2 5 1 20 ) dB) dB) dB 0 0 V/ N ( R ( 15 AI G PE (m –5 –1 ERRO O SL 10 –10 –2 5 –15 –3 –20 –4 0 0.1 0.3 0.5 0.7 0.9 1.1 1.3
003 006
0.1 1 10 100 1k VGAIN (V)
07593-
FREQUENCY (MHz)
07593- Figure 3. Gain and Gain Law Conformance vs. VGAIN Figure 6. Gain Slope vs. Frequency, RFIN = −20 dBm @ 500 MHz, VGAIN = 1 V over Temperature at 100 MHz
20 4 55 15 3 50 10 2 45 40 5 1 dB) dB) 35 0 0 dBm) N ( R ( AI 30 G IP3 ( –5 –1 ERRO O 25 –10 –2 20 –15 –3 15 –20 –4 10 0.1 0.3 0.5 0.7 0.9 1.1 1.3
004
0.5 0.6 0.7 0.8 0.9 1.0 1.1 1.2 1.3 1.4
007
VGAIN (V)
07593-
V GAIN (V)
07593- Figure 4. Gain and Gain Law Conformance vs. VGAIN Figure 7. Output IP3 vs. VGAIN at 100 MHz over Temperature at 400 MHz
20 4 45 15 3 40 10 2 35 5 1 dB) dB) 30 0 0 dBm) N ( R ( AI G IP3 ( 25 –5 –1 ERRO O 20 –10 –2 –15 –3 15 –20 –4 10 0.1 0.3 0.5 0.7 0.9 1.1 1.3
005
008
VGAIN (V)
07593-
V GAIN (V)
07593- Figure 5. Gain and Gain Law Conformance vs. VGAIN Figure 8. Output IP3 vs. VGAIN at 400 MHz over Temperature at 900 MHz Rev. A | Page 6 of 15 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION BASIC CONNECTIONS GAIN CONTROL INPUT CMTS TRANSMIT APPLICATION Interfacing to AD9789 INTERFACING TO AN IQ MODULATOR SOLDERING INFORMATION EVALUATION BOARD SCHEMATIC OUTLINE DIMENSIONS ORDERING GUIDE
