Datasheet HMC694 (Analog Devices) - 5
DescriptionAnalog Variable Gain Amplifier Chip, 6 - 17 GHz
Pages / Page8 / 5 — HMC694. GaAs MMIC ANALOG VARIABLE. GAIN AMPLIFIER, 6 - 17 GHz. Absolute …
File Format / SizePDF / 478 Kb
HMC694. GaAs MMIC ANALOG VARIABLE. GAIN AMPLIFIER, 6 - 17 GHz. Absolute Maximum Ratings. Typical Supply Current vs. Vdd
HMC694 GaAs MMIC ANALOG VARIABLE GAIN AMPLIFIER, 6 - 17 GHz Absolute Maximum Ratings Typical Supply Current vs Vdd
HMC694
v03.1108
GaAs MMIC ANALOG VARIABLE GAIN AMPLIFIER, 6 - 17 GHz Absolute Maximum Ratings Typical Supply Current vs. Vdd
Drain bias Voltage (Vdd1, 2, 3) +5.5V Vdd1,2,3 (V) idd Total (ma) gate bias Voltage (Vgg1, 2) -3 to 0V +5 170 gain Control Voltage (Vctrl) -3 to 0V Vgg1,2 (V) igg Total (ma) rf input power +5 dbm 0V to -2V <3 µa Channel Temperature 175 °C Continuous pdiss (T= 85 °C) 0.92 W (derate 10.2 mW/°C above 85 °C) Thermal resistance 97.6 °C/W eleCTrOsTaTiC sensiTiVe DeViCe (channel to die bottom) ObserVe HanDling preCaUTiOns storage Temperature -65 to +150 °C Operating Temperature -55 to +85 °C 6 ip H
Outline Drawing
s - C r ie lif p m in a a le g b ia r a V
Die Packaging Information
[1] nOTes: standard alternate 1. all DimensiOns in inCHes [millimeTers] 2. nO COnneCTiOn reQUireD fOr UnlabeleD bOnD paDs gp-2 (gel pack) [2] 3. Die THiCKness is 0.004 (0.100) 4. TYpiCal bOnD paD is 0.004 (0.100) sQUare [1] Refer to the “Packaging Information” section for die 5. baCKsiDe meTalliZaTiOn: gOlD packaging dimensions. 6. baCKsiDe meTal is grOUnD [2] For alternate packaging information contact Hittite 7. bOnD paD meTaliZaTiOn: gOlD Microwave Corporation. Inf F or o m rat ip o r n ifc ur e n ,is hd e e d lbiv y e Anry alo a g n D d evi cto es ips la beclie ev eo d rtd o e b r e sa: ccH ur iattte itaen M d reliic a r bl o e w . H a o v weev eC r, o n r o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other poration, 20 Alpha Road, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
6 - 5
Phone: 978-250-3343 Fax: 978-250-3373 rights of third parties that may result from its use. Specifications subject to change without notice. No Or P d hoe n r e O : 7 n- 81-li 3 n 2 e 9- a 4 t 7 0 www 0 • O . rdh e itt r o it n e li . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 p p liocra t ia o pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
