Datasheet AD8336 (Analog Devices) - 5
DescriptionGeneral-Purpose, −55°C to +125°C, Wide Bandwidth, DC-Coupled VGA
Pages / Page27 / 5 — Data Sheet. AD8336. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. Rating. …
RevisionF
File Format / SizePDF / 802 Kb
Data Sheet. AD8336. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. Rating. ESD CAUTION
Data Sheet AD8336 ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
Data Sheet AD8336 ABSOLUTE MAXIMUM RATINGS Table 2.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these Supply Voltage (VPOS, VNEG) ±15 V or any other conditions above those indicated in the operational Input Voltage (INPP, INPN) VPOS, VNEG section of this specification is not implied. Operation beyond Gain Voltage (GPOS, GNEG) VPOS, VNEG the maximum operating conditions for extended periods may PWRA 5 V, GND affect product reliability. VGAI VPOS + 0.6 V, VNEG − 0.6 V Power Dissipation
ESD CAUTION
VS ≤ ±5 V 0.43 W ±5 V < VS ≤ ±12 V 1.12 W Operating Temperature Range ±3 V < VS ≤ ±10 V −55°C to +125°C ±10 V < VS ≤ ±12 V −55°C to +85°C Storage Temperature Range −65°C to +150°C Lead Temperature (Soldering 60 sec) 300°C Thermal Data1 θJA 58.2°C/W θJB 35.9°C/W θJC 9.2°C/W ΨJT 1.1°C/W ΨJB 34.5°C/W 1 4-layer JEDEC board, no airflow, exposed pad soldered to printed circuit board. Rev. F | Page 5 of 27 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION OVERVIEW PREAMPLIFIER VGA SETTING THE GAIN NOISE OFFSET VOLTAGE APPLICATIONS INFORMATION AMPLIFIER CONFIGURATION PREAMPLIFIER Circuit Configuration for Noninverting Gain Circuit Configuration for Inverting Gain USING THE POWER ADJUST FEATURE DRIVING CAPACITIVE LOADS EVALUATION BOARD OPTIONAL CIRCUITRY BOARD LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
