Datasheet AD8337 (Analog Devices) - 5
DescriptionGeneral-Purpose, Low Cost, DC-Coupled VGA
Pages / Page28 / 5 — Data Sheet. AD8337. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter Rating. …
RevisionD
File Format / SizePDF / 978 Kb
Data Sheet. AD8337. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter Rating. ESD CAUTION
Data Sheet AD8337 ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
Data Sheet AD8337 ABSOLUTE MAXIMUM RATINGS Table 2.
Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a
Parameter Rating
stress rating only; functional operation of the product at these Voltage or any other conditions above those indicated in the operational Supply Voltage (VPOS, VNEG) ±6 V section of this specification is not implied. Operation beyond Input Voltage (INPx) VPOS, VNEG the maximum operating conditions for extended periods may GAIN Voltage VPOS, VNEG affect product reliability. Power Dissipation 866 mW (Exposed Pad Soldered to PCB) Temperature
ESD CAUTION
Operating Temperature Range −40°C to +85°C Storage Temperature Range −65°C to +150°C Lead Temperature (Soldering, 60 sec) 300°C Thermal Data, 4-Layer JEDEC Board No Air Flow Exposed Pad Soldered to PCB θJA 75.4°C/W θJB 47.5°C/W θJC 17.9°C/W ΨJT 2.2°C/W ΨJB 46.2°C/W Rev. D | Page 5 of 28 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION OVERVIEW PREAMPLIFIER VGA GAIN CONTROL OUTPUT STAGE ATTENUATOR SINGLE-SUPPLY OPERATION AND AC COUPLING NOISE APPLICATIONS INFORMATION PREAMPLIFIER CONNECTIONS Noninverting Gain Configuration Inverting Gain Configuration DRIVING CAPACITIVE LOADS GAIN CONTROL CONSIDERATIONS THERMAL CONSIDERATIONS PSI (Ψ) BOARD LAYOUT EVALUATION BOARDS CIRCUIT OPTIONS OUTPUT PROTECTION MEASUREMENT SETUP BOARD LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
