Datasheet AD604 (Analog Devices) - 6
DescriptionDual, Ultralow Noise Variable Gain Amplifier
Pages / Page32 / 6 — AD604. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. –DSX1 1. 24 VGN1. …
RevisionG
File Format / SizePDF / 741 Kb
AD604. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. –DSX1 1. 24 VGN1. +DSX1 2. 23 VREF. PAO1 3. 22 OUT1. FBK1 4. 21 GND1. PAI1 5. 20 VPOS
AD604 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS –DSX1 1 24 VGN1 +DSX1 2 23 VREF PAO1 3 22 OUT1 FBK1 4 21 GND1 PAI1 5 20 VPOS
AD604 PIN CONFIGURATION AND FUNCTION DESCRIPTIONS –DSX1 1 24 VGN1 +DSX1 2 23 VREF PAO1 3 22 OUT1 FBK1 4 21 GND1 PAI1 5 20 VPOS AD604 COM1 6 19 VNEG TOP VIEW COM2 7 (Not to Scale) 18 VNEG PAI2 8 17 VPOS FBK2 9 16 GND2 PAO2 10 15 OUT2 +DSX2 11 14 VOCM
2 00
–DSX2 12 13 VGN2
0- 54 00 Figure 2. Pin Configuration
Table 3. Pin Function Descriptions Pin No. Mnemonic Description
1 –DSX1 Channel 1 Negative Signal Input to DSX1. 2 +DSX1 Channel 1 Positive Signal Input to DSX1. 3 PAO1 Channel 1 Preamplifier Output. 4 FBK1 Channel 1 Preamplifier Feedback Pin. 5 PAI1 Channel 1 Preamplifier Positive Input. 6 COM1 Channel 1 Signal Ground. When this pin is connected to positive supply, Preamplifier 1 shuts down. 7 COM2 Channel 2 Signal Ground. When this pin is connected to positive supply, Preamplifier 2 shuts down. 8 PAI2 Channel 2 Preamplifier Positive Input. 9 FBK2 Channel 2 Preamplifier Feedback Pin. 10 PAO2 Channel 2 Preamplifier Output. 11 +DSX2 Channel 2 Positive Signal Input to DSX2. 12 –DSX2 Channel 2 Negative Signal Input to DSX2. 13 VGN2 Channel 2 Gain Control Input and Power-Down Pin. If this pin is grounded, the device is off; otherwise, positive voltage increases gain. 14 VOCM Input to this pin defines the common mode of the output at OUT1 and OUT2. 15 OUT2 Channel 2 Signal Output. 16 GND2 Ground. 17 VPOS Positive Supply. 18 VNEG Negative Supply. 19 VNEG Negative Supply. 20 VPOS Positive Supply. 21 GND1 Ground. 22 OUT1 Channel 1 Signal Output. 23 VREF Input to this pin sets gain scaling for both channels to 2.5 V = 20 dB/V and 1.67 V = 30 dB/V. 24 VGN1 Channel 1 Gain Control Input and Power-Down Pin. If this pin is grounded, the device is off; otherwise, positive voltage increases gain. Rev. G | Page 6 of 32 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION PREAMPLIFIER DIFFERENTIAL LADDER (ATTENUATOR) AC COUPLING GAIN CONTROL INTERFACE ACTIVE FEEDBACK AMPLIFIER (FIXED-GAIN AMP) APPLICATIONS INFORMATION ULTRALOW NOISE AGC AMPLIFIER WITH 82 dB TO 96 dB GAIN RANGE ULTRALOW NOISE, DIFFERENTIAL INPUT-DIFFERENTIAL OUTPUT VGA MEDICAL ULTRASOUND TGC DRIVING THE AD9050, A 10-BIT, 40 MSPS ADC EVALUATION BOARD CONNECTING A WAVEFORM TO THE AD604-EVALZ DSX INPUT CONNECTIONS Cascade VGAs to Boost Gain PREAMPLIFIER GAIN OUTPUTS DC OPERATING CONDITIONS EVALUATION BOARD ARTWORK AND SCHEMATIC OUTLINE DIMENSIONS ORDERING GUIDE
