Datasheet ADRF6516 (Analog Devices) - 6
Description31 MHz, Dual Programmable Filters and Variable Gain Amplifiers
Pages / Page29 / 6 — ADRF6516. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. …
RevisionC
ADRF6516. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 2. Parameter. Rating. ESD CAUTION
ADRF6516 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating ESD CAUTION
ADRF6516 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 2.
Stresses at or above those listed under Absolute Maximum
Parameter Rating
Ratings may cause permanent damage to the product. This is a Supply Voltages, VPS, VPSD 3.45 V stress rating only; functional operation of the product at these ENBL, OFDS, LE, CLK, DATA, SDO VPSD + 0.5 V or any other conditions above those indicated in the operational INP1, INM1, INP2, INM2 VPS + 0.5 V section of this specification is not implied. Operation beyond OPP1, OPM1, OPP2, OPM2 VPS + 0.5 V the maximum operating conditions for extended periods may OFS1, OFS2 VPS + 0.5 V affect product reliability. GAIN VPS + 0.5 V
ESD CAUTION
Internal Power Dissipation 1.25 W θJA (Exposed Pad Soldered to Board) 37.4°C/W Maximum Junction Temperature 150°C Operating Temperature Range −40°C to +85°C Storage Temperature Range −65°C to +150°C Lead Temperature (Soldering 60 sec) 300°C Rev. C | Page 6 of 29 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS REGISTER MAP AND CODES THEORY OF OPERATION INPUT BUFFERS PROGRAMMABLE FILTERS VARIABLE GAIN AMPLIFIERS (VGAs) OUTPUT BUFFERS/ADC DRIVERS DC OFFSET COMPENSATION LOOP PROGRAMMING THE FILTERS AND GAINS NOISE CHARACTERISTICS DISTORTION CHARACTERISTICS MAXIMIZING THE DYNAMIC RANGE KEY PARAMETERS FOR QUADRATURE-BASED RECEIVERS APPLICATIONS INFORMATION BASIC CONNECTIONS SUPPLY DECOUPLING INPUT SIGNAL PATH OUTPUT SIGNAL PATH DC OFFSET COMPENSATION LOOP ENABLED COMMON-MODE BYPASSING SERIAL PORT CONNECTIONS ENABLE/DISABLE FUNCTION ERROR VECTOR MAGNITUDE (EVM) PERFORMANCE EVM TEST SETUP EFFECT OF FILTER BANDWIDTH ON EVM EFFECT OF OUTPUT VOLTAGE LEVELS ON EVM EFFECT OF COFS VALUE ON EVM EVALUATION BOARD EVALUATION BOARD CONTROL SOFTWARE SCHEMATICS AND ARTWORK OUTLINE DIMENSIONS ORDERING GUIDE
