Datasheet HMC625BLP5E (Analog Devices) - 9
Description0.5 dB LSB GaAs MMIC 6-Bit Digital Variable Gain Amplifier, DC - 5 GHz
Pages / Page9 / 9 — HMC625BLP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL. VARIABLE GAIN AMPLIFIER, …
File Format / SizePDF / 692 Kb
HMC625BLP5E. 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL. VARIABLE GAIN AMPLIFIER, DC - 5 GHz. Evaluation PCB
HMC625BLP5E 0.5 dB LSB GaAs MMIC 6-BIT DIGITAL VARIABLE GAIN AMPLIFIER, DC - 5 GHz Evaluation PCB
HMC625BLP5E
v02.0616
T M L - S ITA IG S - D R U1 IE LIF P M IN A A LE G B IA R A
List of Materials for Evaluation PCB 116960 - HMC625BLP5 [1]
V Item Description J1 - J2 PCB Mount SMA Connector The circuit board used in the application should J3 18 Pin DC Connector use RF circuit design techniques. Signal lines J4 - J6 DC Pin should have 50 Ohm impedance while the package C1 - C9 100 pF Capacitor, 0402 Pkg. ground leads and exposed paddle should be C11 - C12 1000 pF Capacitor, 0402 Pkg. connected directly to the ground plane similar to that C14 2.2 µF Capacitor, CASE A Pkg. shown. A sufficient number of via holes should be R1 - R14 100 kOhm Resistor, 0402 Pkg. used to connect the top and bottom ground planes. R15 1.8 Ohm Resistor, 1206 Pkg. The evaluation circuit board shown is available from SW1, SW2 SPDT 4 Position DIP Switch Hittite upon request. L1 24 nH Inductor, 0603 Pkg. U1 HMC625BLP5E Variable Gain Amplifier PCB [2] 116958 Evaluation PCB [1] Reference this number when ordering complete evaluation PCB [2] Circuit Board Material: Arlon 25FR For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
9
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Typical Performance Characteristics Maximum Gain vs. Frequency Normalized Attenuation [2 Input Return Loss [2] Output Return Loss [2] Bit Error vs. Frequency [2] Bit Error vs. Attenuation State [2] Normal Relative Phase vs. Frequency [2] Step Error vs. Frequency [2] Serial Control Interface Parallel Mode (Direct Parallel Mode & Latched Parallel Mode) Power-Up States PUP Truth Table Power-On Sequence Absolute Maximum Ratings Truth Table Bookmark 24 Bias Voltage Outline Drawing Package Information Pin Descriptions Application Circuit Evaluation PCB List of Materials for Evaluation PCB 116960 - HMC625ALP5 [1]
