HMC627ALP5E v00.1212 0.5 dB LSB GaAs MMIC 6-BIT DIGITALVARIABLE GAIN AMPLIFIER, 50 MHz - 1 GHzInput Return Loss [3]Output Return Loss [3] 0 0 -5 -5 31.5 dB ) -10 ) T -10 B IL, 0.5, 1, 2 dB B (d (d S -15 S -15 M S S O O L L -20 -20 N N UR UR -25 -25 T T RE RE L - S -30 4, 8, 16, 31.5 dB -30 -35 -35 ITA -40 -40 0.05 0.1 0.15 0.2 0.25 0.3 0.35 0.05 0.1 0.15 0.2 0.25 0.3 0.35 IG FREQUENCY (GHz) FREQUENCY (GHz) S - D R Bit Error vs. Frequency [3]Bit Error vs. Attenuation State [3] IE 2 2 1.5 1.5 LIF 50 MHz 16, 31.5 dB 1 1 ) P B B d d ( 0.5 ( 0.5 R R M O O R 0 R 0 R R E E -0.5 IT -0.5 IT B B 0.5, 1, 2, 4, 8 dB 100, 150, 200, 250, 300, 350 MHz -1 -1 IN A A -1.5 -1.5 -2 -2 0.05 0.1 0.15 0.2 0.25 0.3 0.35 0 4 8 12 16 20 24 28 32 FREQUENCY (GHz) ATTENUATION STATE (dB) LE G B IA R Normal Relative Phase vs. Frequency [3]Step Error vs. Frequency [3] A 80 1 V 0.8 60 ) g 0.6 e (d B) 0.4 40 0.5, 31.5 dB (d R ASE 0.2 O PH R 20 0 ER IVE -0.2 EP AT 0 ST -0.4 EL 16 dB R 31.5 dB -0.6 -20 16 dB -0.8 8 dB -40 -1 0.05 0.1 0.15 0.2 0.25 0.3 0.35 0.05 0.1 0.15 0.2 0.25 0.3 0.35 FREQUENCY (GHz) FREQUENCY (GHz) [3] Tested with broadband bias tee on RF ports and C1 = 3300 pF; C3, C4 & C5 = 330 pF; L1 = 560 nH I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com 4 Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte ho.c n o e m : 1-800-ANALOG-D
