Datasheet HMC960LP4E (Analog Devices) - 2
DescriptionDC - 100 MHz Dual Digital Variable Gain Amplifier SMT with Driver
Pages / Page20 / 2 — HMC960LP4E. DC - 100 MHz DUAL DigitAL. VAriAbLe gAin AMpLifier with …
HMC960LP4E. DC - 100 MHz DUAL DigitAL. VAriAbLe gAin AMpLifier with DriVer. table 1. electrical Specifications
HMC960LP4E DC - 100 MHz DUAL DigitAL VAriAbLe gAin AMpLifier with DriVer table 1 electrical Specifications
HMC960LP4E
v01.1212
DC - 100 MHz DUAL DigitAL VAriAbLe gAin AMpLifier with DriVer table 1. electrical Specifications
T = +25°C, VDDI, VDDQ, DVDD = 5V +/-10%, GND = 0V, 400 Ω differential load unless otherwise stated. A Parameter Conditions Min. Typ. Max. Units
Analog Performance
Gain Range 0 40 dB Gain Step Size 0.5 dB Gain Step Error f = 40 MHz 0.05 ±0.2 dB Gain Absolute Error f = 40 MHz 0.1 ±0.2 dB DC Offset [4] measured over all gain settings 0 ±50 mV Signal Bandwidth 0.5 dB bandwidth over all gain settings 50 90 MHz 3 dB bandwidth 100 180 MHz Noise Figure Gain: 100 Ω Input Impedance (100 Ohm source) 0 dB (min gain) 23 dB 10 dB 14 dB 20 dB 7.5 dB 30 dB 6.5 dB 40 dB (max gain) 6 dB T 400 Ω Input Impedance (400 Ohm source) 0 dB (min gain) 17.5 dB 10 dB 11 dB M 20 dB 6.7 dB 30 dB 6.3 dB S 40 dB (max gain) 6.1 dB - Output noise measured at f = 1 MHz G 0 dB gain 100 Ω matched input load 9 nV/rtHz 40 dB gain 125 nV/rtHz IN Output IP3 using two tones near 20 MHz S 0 dB gain at 2 Vppd output 32 dBm S 40 dB gain 33 dBm E IM3 using two tones near 20 MHz C 0 dB gain at 2 Vppd output -75 dBc 40 dB gain -80 dBc RO Output IP2 using two tones near 20 MHz 0 dB gain at 2 Vppd output 73 dBm P 40 dB gain 73 dBm D IM2 using two tones near 20 MHz 0 dB gain at 2 Vppd output -80 dBc N 40 dB gain -80 dBc A Sideband Suppression (Uncalibrated)[1] tested at 20 MHz over all gains 40 55 dB B E I/Q Channel Balance[1] tested at 20 MHz Gain 0.02 dB S Phase 0.15 degrees A I/Q Channel Isolation 60 70 dB
Analog I/O
IF/B 100 Ω Mode 80 100 120 Ω Differential input impedance 400 Ω Mode 320 400 480 Ω Full Scale Differential Input min / max gain setting 2/0.02 Vppd 400 Ω Differential Load min / max gain setting 1/0.02 Vppd 100 Ω Differential Load Input Common Mode Voltage Range 1 4 V Inf F or o m r p atio r n fic ur e n , d ishe e d lbiv y e An ry a alog n Ded t viceo p s is la belciee o ved rd to e b r e sa: H ccur iattte itae M nd rel iic a r bl o e. w H a o v we e C ver, noo For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rporation, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 978-250-3343 tel • 978-250-3373 fax • O rights of third parties that may result from its use. Specifications subject to change without notice. No rd P e hor O ne n : 7 -li 81 n -3e a 29- t w 470 ww. 0 • O h rdit e tit r oe n .lic n om license is granted by implication or otherwise under any patent or patent rights of Analog Devices. e at www.analog.com
2
Application S Trademarks and registered trademarks are the property of their respective owners. upport: apps@ Aphpilittciatteio.co n S m upport: Phone: 1-800-ANALOG-D
