Datasheet BC847PN (Diodes) - 3
ManufacturerDiodes
DescriptionNpn+pnp
Pages / Page6 / 3 — BC847PN. Electrical Characteristics:. NPN, BC847B Type (Q1). …
File Format / SizePDF / 464 Kb
BC847PN. Electrical Characteristics:. NPN, BC847B Type (Q1). Characteristic (Note 6). Symbol. Min. Typ. Max. Unit. Test Condition
BC847PN Electrical Characteristics: NPN, BC847B Type (Q1) Characteristic (Note 6) Symbol Min Typ Max Unit Test Condition
(@TA = +25°C, unless otherwise specified.)
Collector-Base Breakdown Voltage BVCBO 50 — — V IC = 100µA Collector-Emitter Breakdown Voltage BVCEO 45 — — V IC = 10mA Emitter-Base Breakdown Voltage BVEBO 6 — — V IE = 100µA DC Current Gain hFE 200 290 450 — VCE = 5.0V, IC = 2.0mA 90 250 I Collector-Emitter Saturation Voltage V C = 10mA, IB = 0.5mA CE(SAT) — mV 200 600 IC = 100mA, IB = 5.0mA 700 I Base-Emitter Saturation Voltage V — C = 10mA, IB = 0.5mA BE(SAT) — mV 900 IC = 100mA, IB = 5.0mA 580 660 700 V Base-Emitter Voltage V CE = 5.0V, IC = 2.0mA BE(ON) — mV — 720 VCE = 5.0V, IC = 10mA — — 15 nA V Collector-Cutoff Current I CB = 30V CBO — — 5.0 µA VCB = 30V, TA = +150°C V Gain Bandwidth Product f CE = 5.0V, IC = 10mA, T 100 300 — MHz f = 100MHz Collector-Base Capacitance CCBO — 3.5 6.0 pF VCB = 10V, f = 1.0MHz VCE = 5V, IC = 200µA, Noise Figure NF — 2.0 10 dB Rg = 2.0kΩf = 1.0kHz, f = 200Hz Note: 6. Short duration pulse test used to minimize self-heating effect. 1,000 0.5 I C I = 20 B 0.4 R ) N E V I ( T A TI E G 100 G M T A E T N - L 0.3 E R O R O V R T U C N C E O L I T C L 0.2 A T = 100°C A D O R , 10 C E , U F T h E C A V S 0.1 T = 25 C ° A T = -50 C 1 0 A ° 0.01 0.1 1.0 10 100 0.1 1.0 10 100 I , COLLECTOR CURRENT (mA) I , COLLECTOR CURRENT (mA) C C Figure 2. Typical DC Current Gain vs. Collector Current Figure 3. Typical Collector-Emitter Saturation Voltage (BC847B Type) vs. Collector Current (BC847B Type) 1,000 T = 25°C A f = 1MHz ) z H M V = 10V ( CE T C ) F U p D ( 10 O V =5V CE E R C P V = 2V N CE H A 100 T T I D C I A W 6 P Cibo D A N C A B- NI A Cobo G , f T 10 0.1 1.0 10 100 V , REVERSE VOLTAGE (V) I , COLLECTOR CURRENT (mA) R C Figure 4. Typical Capacitance Characteristics (BC847B Type) Figure 5. Typical Gain-Bandwidth Product vs. Collector Current (BC847B Type) BC847PN 3 of 6 June 2016 Document number: DS30278 Rev. 14 - 2
www.diodes.com
© Diodes Incorporated
