BC847BSFeatures • For Switching and AF Amplifier Applications • Halogen Free Available Upon Request By Adding Suffix "-HF" • Moisture Sensitivity Level 1 Dual NPN • Epoxy Meets UL 94 V-0 Flammability Rating • Lead Free Finish/RoHS Compliant ("P" Suffix Designates RoHS Small Signal Compliant. See Ordering Information) TransistorsMaximum Ratings @ 25°C Unless Otherwise Specified • Operating Junction Temperature Range: -55℃ to +150℃ • Operating Junction Temperature Range: -55℃ to +150℃ • Thermal Resistance: 417℃/W Junction to Ambient SOT-363 ParameterSymbolRatingUnit Collector-Base Voltage VCBO 50 V G Collector-Emitter Voltage VCEO 45 V Emitter-Base Voltage VEBO 6 V B C Collector Current I • C 100 mA Peak Collector Current ICM 200 mA A Power Dissipation PD 300 mW M H K L J Internal Structure D DIMENSIONS 6 5 4 DIM INCHES MM NOTE MIN MAX MIN MAX A 0.006 0.014 0.15 0.35 B 0.045 0.053 1.15 1.35 C 0.079 0.096 2.00 2.45 Marking: 1C D 0.026 0.65 TYP. G 0.047 0.055 1.20 1.40 1 2 3 H 0.071 0.087 1.80 2.20 J ----- 0.004 ----- 0.10 K 0.031 0.043 0.80 1.10 L 0.010 0.018 0.26 0.46 M 0.003 0.006 0.08 0.15 Suggested Solder Pad Layout Rev.3-1-01012019 1/4 MCCSEMI.COM
