Datasheet BC846AW, BC846BW, BC847AW, BC847BW, BC847CW, BC848AW, BC848BW, BC848CW (MCC) - 2
ManufacturerMCC
DescriptionNPN General Purpose Transistors SOT-323
Pages / Page5 / 2 — Micro Commercial Components. Symbol. Parameter. Min. Typ. Max. Units. 2 …
File Format / SizePDF / 573 Kb
Micro Commercial Components. Symbol. Parameter. Min. Typ. Max. Units. 2 of 5
Micro Commercial Components Symbol Parameter Min Typ Max Units 2 of 5
M C C TM
ON CHARACTERISTICS
ICBO Collector-base Cut-off Current (ICE=0, VCB=30Vdc) --- --- 15 nA (ICE=0, VCB=30Vdc, Tj=150к) --- --- 5 µA IEBO Emitter-base Cut-off Current (IC=0, VEB=5Vdc) --- --- 100 nA VCE(sat) Collector-Emitter Saturation Voltage (IC=10mAdc, IB=0.5mAdc) --- 90 250 mVdc (IC=100mAdc, IB=5mAdc*) --- 200 600 mVdc VBE(sat) Base-Emitter Saturation Voltage (IC=10mAdc,IB=0.5mAdc) --- 700 --- mVdc (IC=100mAdc, IB=5mAdc*) --- 900 --- mVdc hFE DC Current Gain (IC=10µA; VCE=5V) BC846AW; BC847AW;BC848AW --- 90 --- BC846BW; BC847BW;BC848BW --- 150 --- BC847CW;BC848CW --- 270 --- DC Current Gain (IC=2mA; VCE=5V) BC846AW; BC847AW;BC848AW 110 180 220 BC846BW; BC847BW;BC848BW 200 290 450 BC847CW;BC848CW 420 520 800 VBE Base-emitter Voltage (IC=2mAdc,VCE=5V) 580 660 700 mVdc (IC=10mAdc,VCE=5V) --- --- 770 mVdc Cc Collector Capacitance (VCB=10V; IE=Ie=0; f=1MHz) --- --- 4.5 pF fT Transition Frequency (VCE=5V; IC=10mA; f=100MHz) 100 --- --- MHz F Noise Figure (VCE=5V; IC=200µA; f=1KHz; B=200Hz; RS=2K¡) --- --- 10 dB * Pulse test: tP̰300µs; ¥̰0.02 www.mccsemi.com Revision: C
2 of 5
2013/09/24
