Datasheet AL8860Q (Diodes) - 9
Manufacturer | Diodes |
Description | High Efficiency 40V 1.5A Automotive Grade Buck LED Driver |
Pages / Page | 15 / 9 — AL8860Q. Application Information. AL8860Q Operation. U D. R P. E N. LED … |
File Format / Size | PDF / 1.0 Mb |
AL8860Q. Application Information. AL8860Q Operation. U D. R P. E N. LED Current Configuration. Nominal Average Output Current (mA)
AL8860Q Q Application Information
The AL8860Q is a hysteretic mode LED driver with integrated power switch, and is available in thermal enhanced MSOP-8EP package.
AL8860Q Operation
In normal operation, when normal input voltage is applied at VIN pin, the AL8860Q internal switch will turn on. Current starts to flow through the sense resistor RS, the inductor L1, and the LEDs. The current ramps up linearly, and the slew rate is determined by the input voltage VIN, VOUT and the inductor L1.
T
This rising current produces a voltage ramp across RS. The internal circuit of the AL8860Q senses the voltage across RS and applies a
C
proportional voltage to the input of the internal comparator. When this voltage reaches an internal upper threshold, the internal switch is turned off.
U D
The inductor current continues to flow through RS, L1, LEDs and diode D1, and back to the supply rail, but it decays with the rate determined by
O
the forward voltage drop of LEDs and the diode D1.
R P
This decaying current produces a falling voltage on RS, which is sensed by the AL8860Q. A voltage proportional to the sense voltage across RS
W
will be applied at the input of internal comparator. When this voltage falls to the internal lower-set threshold, the internal switch is turned on again.
E N
This switch-on-and-off cycle continues to provide the average LED current set by the sense resistor RS.
The nominal average output current in the LED(s) is determined by the value of the external current sense resistor (RS) connected between VIN pin and SET pin, and is given by: The table below provides values of nominal average output current for setting resistor (RS) in the Typical Application Circuit shown on page 1.
R
(Ω)
S Nominal Average Output Current (mA)
0.066 1500 0.1 1000 0.13 760 0.15 667 0.3 333 The above values assume that the CTRL pin is floating and at a nominal reference voltage for internal comparator. It is possible to use different values of RS if the CTRL pin is driven by an external dimming signal.
Analog Dimming
Applying a DC voltage from 0.3V to 2.5V on CTRL pin can adjust output current from 0 to 100% of IOUT
_
NOM linearly, as shown in Figure 1. If the CTRL pin is brought higher than 2.5V, the LED current will be clamped to 100% of IOUT
_
NOM. And the output switch will turn off if the CTRL voltage falls below the threshold of 0.3V.
PWM Dimming
The LED current can be adjusted digitally by applying a low frequency Pulse-Width-Modulated (PWM) logic signal to the CTRL pin to turn the device on and off. This will produce an average output current proportional to the duty cycle of the control signal. To achieve a high resolution, the PWM frequency is recommended to be lower than 500Hz, however high dimming frequencies can be used at the expense of dimming dynamic range and accuracy. Typically, for a PWM frequency of 500Hz, the accuracy is better than 1% for PWM ranging from 1% to 100%. The accuracy of the low duty cycle dimming is affected by both the PWM frequency and also the switching frequency of the AL8860Q. For best accuracy/resolution, the switching frequency should be increased while the PWM frequency should be reduced. The CTRL pin is designed to be driven by both 3.3V and 5V logic levels directly from a logic output with either an open drain output or a push-pull output stage. AL8860Q 9 of 15 May 2019 Document number: DS41797 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated
