Datasheet RV1S9060A (Renesas)
ManufacturerRenesas
DescriptionHIGH CMR, 15Mbps CMOS OUTPUT, LOW FORWARD-CURRENT(IF) 3.3V/5V OPERATION, 5-PIN with 8mm creepage distance package LSO5 PHOTOCOUPLER
Pages / Page14 / 1 — Data. Sheet. RV1S9060A. R08DS0168EJ0100. Rev.1.00. HIGH. CMR,. 15Mbps. …
Data. Sheet. RV1S9060A. R08DS0168EJ0100. Rev.1.00. HIGH. CMR,. 15Mbps. CMOS. OUTPUT,. LOW. FORWARD-CURRENT(IF). 3.3V/5V. OPERATION,. Jun. 4,. 2019. 5-PIN
Datasheet RV1S9060A Renesas
Data Sheet RV1S9060A R08DS0168EJ0100 Rev.1.00 HIGH CMR, 15Mbps CMOS OUTPUT, LOW FORWARD-CURRENT(IF) 3.3V/5V OPERATION, Jun 4, 2019 5-PIN with 8mm creepage distance package LSO5 PHOTOCOUPLER DESCRIPTION The RV1S9060A is a photocoupler featuring high-speed switching up to 15Mbps with active low output logic which consist of an AlGaAs LED on the input side and an integrated circuit with a photodiode on the output. This product enables to low current operation on 3.3V/5V power supply with high noise-tolerant CMR:50kV/us min. and high temperature operation up to Ta=125°C in logic interface circuit. FEATURES Long creepage distance (8 mm MIN) High speed communication (15 Mbps) High temperature operation (-40 to +125°C) High common mode (dv/dt) tolerant (CMH, CML = 50 kV/s MIN.) High isolation voltage (BV = 5000 Vr.m.s.) Low input drive current (IFHL = 2.2 mA MAX.) Low voltage power supply operation (VDD = 2.7 V~5.5 V) Low pulse width distortion (PWD = 20 ns MAX.) Ordering number of tape product : RV1S9060ACCSP-10Yx#KC0:3000pcs/reel Pb free product Safety standards approval UL :UL1577, Double protection CSA :CAN/CSA-C22.2 No.62368-1, Reinforced insulation VDE :DIN EN 60747-5-5 (Option) TRUTH TABLE APPLICATIONS FA Network Measurement, Control Equipment (Inverter, AC Servo) R08DS0168EJ0100 Rev.1.00 Page 1 of 13 Jun 4, 2019
