Datasheet SLDC (Songle Relay)
ManufacturerSongle Relay
DescriptionAutomotive Relay 30A/40A
Pages / Page4 / 1 — SLDC. Series. AUTOMOTIVE. RELAY. 30A/40A. 21.5MAX. X. Features. A. M5. …
File Format / SizePDF / 8.7 Mb
SLDC. Series. AUTOMOTIVE. RELAY. 30A/40A. 21.5MAX. X. Features. A. M5. 28.5MAX. 1. ·40A. switching. capability. X. A. ·Variety. of. installations. M. .3. 5. 2
Datasheet SLDC Songle Relay
SLDCA
SLDC Series AUTOMOTIVE RELAY 30A/40A 21.5MAX X Features A M5 28.5MAX 1 ·40A switching capability X A ·Variety of installations M .3 5 2 ·Dustproof cover type Ordering Information Contact Rating SLDC-12-S-1- R-C Contact arrangment A /B/C A / B / C Voltage drop ≤ Contact arrangment 200mV R:resistor/D:diode Without w : ithout paral el components Contact material Silver alloy: Paralle c l oil components AgCdO、AgSnO2、AgNi 1.PCB type 2.Plastic bracket, QC terminal Contact rating 3.Metal bracket, QC terminal 30A/40A 14VDC Without: QC terminal Version Max switching voltage 50VDC S sealed / F dustproof Construction Max switching current 40A (resistive 14VDC) 12VDC/ 24VDC Min contact load 1A 6VDC Coil Voltage Electrical endurance 1x10 5ops (frequency: 900 ops/h) Part number endurance Mechanical 1x10 ops 7 (frequency: 18000 ops/h) Characteristics Coil Data ( 20 at ℃) Insulation system Class B / Class F Power Voltage Current Resistance dissipation Pick-up Drop-out Max Insulation resistance 100MΩ(500VDC) W VDC ± Ω 10% Ω voltage voltage allowable Dielectric Between contacts 550VAC 1minute 1. 6 12 90 Strength and coil Between open 1. 8 12 90 680 550VAC 1minute contacts 1. 6 24 360 Operate time(Under nominal voltage) ≤10ms 1. 8 24 360 2700 70%Max 10%Min 130% Release time(Under nominal voltage) ≤10ms 1. 8 24 320 Humidity 85% RH(20℃) 2 24 320 2700 Ambient Temperature -40℃~+125℃ Functional 98m/s
²
Shock resistance Destructive 980m/s
²
Vibration resistance 10Hz
55Hz 1
5mm ( Double amplitude) Approx 36g Weight Construction Dustproof and Sealed type Remark:1)All above data is initial value This product specification only for your reference, we will not notify you if we do any improvement.We reserve all the right for the final explanation Web:www.songle.com www.songlerelay.com Email:sale@songle.com Web:www.songle.com www.songlerelay.com Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China i Z p Code:315400 Add.:CW7, Zone A, Far East Industrial Park, Yuyao City, Zhejiang, China Zip Code:315400 Tel.: +86 574 62717777 62762658 62721968 a F x:+86 574 62721978 Document Outline 页 1 页 2 页 3 页 4
