Datasheet MAX5527, MAX5528, MAX5529 (Maxim) - 5
ManufacturerMaxim
Description64-Tap, One-Time Programmable, Linear-Taper Digital Potentiometers
Pages / Page12 / 5 — One-Time Programmable, Linear-Taper Digital. Potentiometers. …
File Format / SizePDF / 223 Kb
One-Time Programmable, Linear-Taper Digital. Potentiometers. MAX5527/MAX5528/MAX5529
One-Time Programmable, Linear-Taper Digital Potentiometers MAX5527/MAX5528/MAX5529
One-Time Programmable, Linear-Taper Digital Potentiometers MAX5527/MAX5528/MAX5529 Typical Operating Characteristics (continued)
(VDD = +5V, TA = +25°C, unless otherwise noted.)
STATIC SUPPLY CURRENT STATIC SUPPLY CURRENT SUPPLY CURRENT vs. TEMPERATURE vs. SUPPLY VOLTAGE vs. DIGITAL INPUT VOLTAGE
300 300 1000 CS = U/D = GND CS = U/D = GND 250 250 MAX5527 toc10 MAX5527 toc11 MAX5527 toc12 100 VDD = 5V VDD = 5V µA) 200 200 10 V 150 150 DD = 3V 1 100 100 SUPPLY CURRENT (nA) VDD = 3V SUPPLY CURRENT (nA) SUPPLY CURRENT ( 0.1 50 50 0 0 0.01 -40 -15 10 35 60 85 110 2.5 3.0 3.5 4.0 4.5 5.0 5.5 0 1 2 3 4 5 6 TEMPERATURE (°C) SUPPLY VOLTAGE (V) DIGITAL INPUT VOLTAGE (V)
MIDSCALE WIPER RESPONSE TOTAL HARMONIC DISTORTION vs. FREQUENCY vs. FREQUENCY
0 -40 MIDSCALE, 1VRMS, -50 RL = 100kΩ -3 MAX5527 toc13 MAX5527 toc14 MAX5529 -60 -6 -70 MAX5527 MAX5528 -9 GAIN (dB) MAX5528 THD (dB) -80 -12 -90 -15 MAX5527 -100 MAX5529 -18 -110 0.1 1 10 100 1000 10,000 0.01 0.1 1 10 100 FREQUENCY (kHz) FREQUENCY (kHz)
TAP-TO-TAP SWITCHING TRANSIENT
MAX5527 toc15 U/D 2V/div GND OUTPUT W 50mV/div 400ns
_______________________________________________________________________________________ 5
