Datasheet MAX98390 (Maxim) - 10
Manufacturer | Maxim |
Description | Boosted Class-D Amplifier with Integrated Dynamic Speaker Management |
Pages / Page | 209 / 10 — Absolute Maximum Ratings. Note 1:. Package Information. 36 WLP. Thermal … |
File Format / Size | PDF / 4.1 Mb |
Absolute Maximum Ratings. Note 1:. Package Information. 36 WLP. Thermal Resistance, Four-Layer Board:. Electrical Characteristics
link to page 40 MAX98390 Boosted Class-D Amplifier with Integrated Dynamic Speaker Management
VBAT to PGND ... -0.3V to 6V Short-Circuit Duration Between OUTP, OUTN, and PVDD to PGND (Note 1) .. -0.3V to 12V GND .. Continuous DVDD to GND ... -0.3V to 2.15V Short-Circuit Duration Between OUTP, OUTN, and OUTP, OUTN to PGND ... -0.3V to PVDD + 0.3V PVDD .. Continuous LX to PGND ... -0.3V to PVDD + 0.3V Junction Temperature ... +150°C VSNSP, VSNSN to PGND ... -0.3V to 12V Operating Temperature Range ...-40°C to +85°C SDA, SCL, ADDR1, ADDR2 to GND .. -0.3V to 5V Storage Temperaure Range ...-65°C to +150°C PGND to GND ... -0.3V to 0.3V Soldering Temperature (reflow) ..+260°C All other digital pins to GND .. -0.3V to DVDD + 0.3V Short-Circuit Duration Between OUTP and OUTN ... Continuous
Note 1:
When supplying PVDD externally, care must be taken to ensure PVDD is applied only when VBAT is present and the device is enabled. See the Supplying PVDD Externally section for the required sequence. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability.
Package Information 36 WLP
Package Code W362G2+1 Outline Number 21-100287 Land Pattern Number Refer to Application Note 1891
Junction to Ambient (θJA) 46.2°C/W Junction to Case (θJC) N/A For the latest package outline information and land patterns (footprints), go to www.maximintegrated.com/packages. Note that a “+”, “#”, or “-” in the package code indicates RoHS status only. Package drawings may show a different suffix character, but the drawing pertains to the package regardless of RoHS status. Package thermal resistances were obtained using the method described in JEDEC specification JESD51-7, using a four-layer board. For detailed information on package thermal considerations, refer to www.maximintegrated.com/thermal-tutorial.
(VVBAT = 3.7V, VDVDD = 1.8V, VGND = 0V, VPGND = 0V, VPVDD = 10V (BST_VOUT = 11100b), L1 = 1µH, CVBAT = 10µF + 0.1µF + 10µF, CPVDD = 0.1µF + 10µF + 10μF, CDVDD = 0.1µF, CVREFC = 1µF, RVREFC = 30Ω, Amplifier Volume = +0dB (DSM_VOL_CTRL = 0xA0), ZSPK = ∞ between OUTP and OUTN, AC Measurement Bandwidth = 20Hz to 20kHz, PCM_MSTR_MODE = 00b, fS = 48kHz, fBCLK = 3.072MHz, BST_BYP_MODE = 00b (automatic), AMP_FET_SCALE_MODE = 00b (automatic), DSP_GLOBAL_EN = 0, TA = TMIN to TMAX, typical values are at TA = +25°C.) (Note 2)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS SYSTEM
Power-Supply Voltage VVBAT 2.65 5.5 V Range VDVDD 1.71 1.89 www.maximintegrated.com Maxim Integrated | 10 Document Outline General Description Applications Benefits and Features Simplified Block Diagram Absolute Maximum Ratings Package Information 36 WLP Electrical Characteristics Typical Operating Characteristics Pin Configuration 36 WLP Pin Description Functional Diagram MAX98390 Detailed Description Integrated Dynamic Speaker Management (DSM) DSM Sound Studio Thermal and Excursion Protection Low-Frequency Extension Perceptual Power Reduction (PPR) Stereo Bass Management Debuzzer Dynamic Range Compression Equalizer Reading and Writing DSM Registers Interrupts IRQ Pin Configuration Interrupt Sources Boost Converter Soft-Start Boost Output Undervoltage Lockout Boost Overvoltage Protection Programmable Boost Input Current Limit Boost-Clock Phase Boost-Skip Mode Supplying PVDD Externally Boost Envelope Tracker Automatic Boost Bypass Delay for Envelope Tracker and Automatic Boost Bypass Host Fault Handling Clock Monitor BCLK and LRCLK Rate Detection PCM Framing Error Detection Input Data Monitor Watchdog Timer Software Mode Hardware Mode PCM Interface PCM Master/Slave Modes and MCLK Interface Formats—All Modes PCM Clock Ratio Configuration I2S and Left-Justified Modes TDM Modes Invalid TDM Configurations PCM Data Path Configuration PCM Data Input PCM Data Output PCM Interface Timing Logic Output Pin Drive Strength Control Tone Generator Thermal Warning and Shutdown Minimum Valid Setup Thermal Thresholds Amplifier Path Controls Path Routing Control Power Gating and Auto Muting PCM Dither DAC Inversion DC Blocking Filter Digital Volume Control Dynamic Range Extension (DRE) DSP Monitor Class-D Amplifier Output Short-Circuit Detection Spread-Spectrum Modulation Output Sensing When Using Ferrite Beads Ultra-Low EMI Filterless Output Stage FET Scaling Current and Voltage Sense I/V Sense Channel Sharing Measurement ADC Brownout-Detection Engine (BDE) BDE Gain, Limit, and Clip Mirroring BDE Enable Control VBAT Measurement Brownout Controller Brownout Interrupts Limiter Gain Reduction Level 4 Mute Clipper Boost Input Current Limit Using Brownout Boost Input Current Limit to Avoid System Brownouts Interchip Communication ICC Operation and Data Format Multiamplifier Grouping Shutdown Modes Software Shutdown Software Reset Hardware Shutdown I2C Serial Interface Slave Address Bit Transfer START and STOP Conditions Early STOP Conditions Acknowledge Write Data Format Read Data Format I2C Register Map Control Bit Types and Write-Access Restrictions Register Map Register Map Register Details SOFTWARE RESET (0x2000) INTERRUPT RAW 1 (0x2002) INTERRUPT RAW 2 (0x2003) INTERRUPT RAW 3 (0x2004) INTERRUPT STATE 1 (0x2005) INTERRUPT STATE 2 (0x2006) INTERRUPT STATE 3 (0x2007) INTERRUPT FLAG 1 (0x2008) INTERRUPT FLAG 2 (0x2009) INTERRUPT FLAG 3 (0x200A) INTERRUPT ENABLE 1 (0x200B) INTERRUPT ENABLE 2 (0x200C) INTERRUPT ENABLE 3 (0x200D) INTERRUPT FLAG CLEAR 1 (0x200E) INTERRUPT FLAG CLEAR 2 (0x200F) INTERRUPT FLAG CLEAR 3 (0x2010) IRQ CONTROL (0x2011) CLOCK MONITOR CONTROL (0x2012) DATA MONITOR CONTROL (0x2014) WATCHDOG CONTROL (0x2015) WATCHDOG SW RESET (0x2016) MEAS ADC THERMAL WARNING THRESHHOLD (0x2017) MEAS ADC THERMAL SHUTDOWN THRESHHOLD (0x2018) MEAS ADC THERMAL HYSTERESIS (0x2019) PIN CONFIG (0x201A) PCM RX ENABLES A (0x201B) PCM RX ENABLES B (0x201C) PCM TX ENABLES A (0x201D) PCM TX ENABLES B (0x201E) PCM TX HIZ CONTROL A (0x201F) PCM TX HIZ CONTROL B (0x2020) PCM CHANNEL SOURCES 1 (0x2021) PCM CHANNEL SOURCES 2 (0x2022) PCM CHANNEL SOURCES 3 (0x2023) PCM MODE CONFIG (0x2024) PCM MASTER MODE (0x2025) PCM CLOCK SETUP (0x2026) PCM SAMPLE RATE SETUP 1 (0x2027) ICC RX ENABLES A (0x202C) ICC RX ENABLES B (0x202D) ICC TX ENABLES A (0x202E) ICC TX ENABLES B (0x202F) ICC HIZ MANUAL MODE (0x2030) ICC TX HIZ ENABLES A (0x2031) ICC TX HIZ ENABLES B (0x2032) ICC LINK ENABLES (0x2033) AMP DSP CONFIG (0x2039) AMP ENABLES (0x203A) TONE GENERATOR AND DC CONFIG (0x203B) SPEAKER SOURCE SELECT (0x203C) SSM CONFIGURATION (0x203E) MEASUREMENT ENABLES (0x203F) MEASUREMENT DSP CONFIG (0x2040) BOOST CONTROL 0 (0x2041) BOOST CONTROL 3 (0x2042) BOOST CONTROL 1 (0x2043) MEAS ADC CONFIG (0x2044) MEAS ADC BASE DIVIDE MSBYTE (0x2045) MEAS ADC BASE DIVIDE LSBYTE (0x2046) MEAS ADC CHAN 0 DIVIDE (0x2047) MEAS ADC CHAN 1 DIVIDE (0x2048) MEAS ADC CHAN 2 DIVIDE (0x2049) MEAS ADC CHAN 0 FILT CONFIG (0x204A) MEAS ADC CHAN 1 FILT CONFIG (0x204B) MEAS ADC CHAN 2 FILT CONFIG (0x204C) MEAS ADC CHAN 0 READBACK (0x204D) MEAS ADC CHAN 1 READBACK (0x204E) MEAS ADC CHAN 2 READBACK (0x204F) DSP POWER GATING CONTROL (0x2050) DSP POWER GATING STATUS (0x2051) VBAT LOWEST STATUS (0x2052) PVDD LOWEST STATUS (0x2053) BROWNOUT STATUS (0x2054) BROWNOUT ENABLES (0x2055) BROWNOUT LEVEL INFINITE HOLD (0x2056) BROWNOUT LEVEL INFINITE HOLD CLEAR (0x2057) BROWNOUT LEVEL HOLD (0x2058) BROWNOUT LEVEL 1 THRESHOLD (0x2059) BROWNOUT LEVEL 2 THRESHOLD (0x205A) BROWNOUT LEVEL 3 THRESHOLD (0x205B) BROWNOUT LEVEL 4 THRESHOLD (0x205C) BROWNOUT THRESHOLD HYSTERYSIS (0x205D) BROWNOUT AMP LIMITER ATTACK RELEASE (0x205E) BROWNOUT AMP GAIN ATTACK RELEASE (0x205F) BROWNOUT AMP1 CLIP MODE (0x2060) BROWNOUT LEVEL 1 CURRENT LIMIT (0x2061) BROWNOUT LEVEL 1 AMP 1 CONTROL 1 (0x2062) BROWNOUT LEVEL 1 AMP 1 CONTROL 2 (0x2063) BROWNOUT LEVEL 1 AMP 1 CONTROL 3 (0x2064) BROWNOUT LEVEL 2 CURRENT LIMIT (0x2065) BROWNOUT LEVEL 2 AMP 1 CONTROL 1 (0x2066) BROWNOUT LEVEL 2 AMP 1 CONTROL 2 (0x2067) BROWNOUT LEVEL 2 AMP 1 CONTROL 3 (0x2068) BROWNOUT LEVEL 3 CURRENT LIMIT (0x2069) BROWNOUT LEVEL 3 AMP 1 CONTROL 1 (0x206A) BROWNOUT LEVEL 3 AMP 1 CONTROL 2 (0x206B) BROWNOUT LEVEL 3 AMP 1 CONTROL 3 (0x206C) BROWNOUT LEVEL 4 CURRENT LIMIT (0x206D) BROWNOUT LEVEL 4 AMP 1 CONTROL 1 (0x206E) BROWNOUT LEVEL 4 AMP 1 CONTROL 2 (0x206F) BROWNOUT LEVEL 4 AMP 1 CONTROL 3 (0x2070) BROWNOUT LOWEST STATUS (0x2071) BROWNOUT ILIM HOLD (0x2072) BROWNOUT LIM HOLD (0x2073) BROWNOUT CLIP HOLD (0x2074) BROWNOUT GAIN HOLD (0x2075) ENV TRACKER VOUT HEADROOM (0x2076) ENV TRACKER BOOST VOUT DELAY (0x2077) ENV TRACKER RELEASE RATE (0x2078) ENV TRACKER HOLD RATE (0x2079) ENV TRACKER CONTROL (0x207A) ENV TRACKER BOOST VOUT READBACK (0x207B) BOOST BYPASS 1 (0x207C) BOOST BYPASS 2 (0x207D) BOOST BYPASS 3 (0x207E) FET SCALING 1 (0x207F) FET SCALING 2 (0x2080) FET SCALING 3 (0x2081) FET SCALING 4 (0x2082) ADVANCED SETTINGS (0x2084) DSM_EQ_BQ1_B0_BYTE0 (0x2129) DSM_EQ_BQ1_B0_BYTE1 (0x212A) DSM_EQ_BQ1_B0_BYTE2 (0x212B) DSM_EQ_BQ1_B1_BYTE0 (0x212D) DSM_EQ_BQ1_B1_BYTE1 (0x212E) DSM_EQ_BQ1_B1_BYTE2 (0x212F) DSM_EQ_BQ1_B2_BYTE0 (0x2131) DSM_EQ_BQ1_B2_BYTE1 (0x2132) DSM_EQ_BQ1_B2_BYTE2 (0x2133) DSM_EQ_BQ1_A1_BYTE0 (0x2135) DSM_EQ_BQ1_A1_BYTE1 (0x2136) DSM_EQ_BQ1_A1_BYTE2 (0x2137) DSM_EQ_BQ1_A2_BYTE0 (0x2139) DSM_EQ_BQ1_A2_BYTE1 (0x213A) DSM_EQ_BQ1_A2_BYTE2 (0x213B) DSM_EQ_BQ2_B0_BYTE0 (0x213D) DSM_EQ_BQ2_B0_BYTE1 (0x213E) DSM_EQ_BQ2_B0_BYTE2 (0x213F) DSM_EQ_BQ2_B1_BYTE0 (0x2141) DSM_EQ_BQ2_B1_BYTE1 (0x2142) DSM_EQ_BQ2_B1_BYTE2 (0x2143) DSM_EQ_BQ2_B2_BYTE0 (0x2145) DSM_EQ_BQ2_B2_BYTE1 (0x2146) DSM_EQ_BQ2_B2_BYTE2 (0x2147) DSM_EQ_BQ2_A1_BYTE0 (0x2149) DSM_EQ_BQ2_A1_BYTE1 (0x214A) DSM_EQ_BQ2_A1_BYTE2 (0x214B) DSM_EQ_BQ2_A2_BYTE0 (0x214D) DSM_EQ_BQ2_A2_BYTE1 (0x214E) DSM_EQ_BQ2_A2_BYTE2 (0x214F) DSM_EQ_BQ3_B0_BYTE0 (0x2151) DSM_EQ_BQ3_B0_BYTE1 (0x2152) DSM_EQ_BQ3_B0_BYTE2 (0x2153) DSM_EQ_BQ3_B1_BYTE0 (0x2155) DSM_EQ_BQ3_B1_BYTE1 (0x2156) DSM_EQ_BQ3_B1_BYTE2 (0x2157) DSM_EQ_BQ3_B2_BYTE0 (0x2159) DSM_EQ_BQ3_B2_BYTE1 (0x215A) DSM_EQ_BQ3_B2_BYTE2 (0x215B) DSM_EQ_BQ3_A1_BYTE0 (0x215D) DSM_EQ_BQ3_A1_BYTE1 (0x215E) DSM_EQ_BQ3_A1_BYTE2 (0x215F) DSM_EQ_BQ3_A2_BYTE0 (0x2161) DSM_EQ_BQ3_A2_BYTE1 (0x2162) DSM_EQ_BQ3_A2_BYTE2 (0x2163) DSM_EQ_BQ4_B0_BYTE0 (0x2165) DSM_EQ_BQ4_B0_BYTE1 (0x2166) DSM_EQ_BQ4_B0_BYTE2 (0x2167) DSM_EQ_BQ4_B1_BYTE0 (0x2169) DSM_EQ_BQ4_B1_BYTE1 (0x216A) DSM_EQ_BQ4_B1_BYTE2 (0x216B) DSM_EQ_BQ4_B2_BYTE0 (0x216D) DSM_EQ_BQ4_B2_BYTE1 (0x216E) DSM_EQ_BQ4_B2_BYTE2 (0x216F) DSM_EQ_BQ4_A1_BYTE0 (0x2171) DSM_EQ_BQ4_A1_BYTE1 (0x2172) DSM_EQ_BQ4_A1_BYTE2 (0x2173) DSM_EQ_BQ4_A2_BYTE0 (0x2175) DSM_EQ_BQ4_A2_BYTE1 (0x2176) DSM_EQ_BQ4_A2_BYTE2 (0x2177) DSM_EQ_BQ5_B0_BYTE0 (0x2179) DSM_EQ_BQ5_B0_BYTE1 (0x217A) DSM_EQ_BQ5_B0_BYTE2 (0x217B) DSM_EQ_BQ5_B1_BYTE0 (0x217D) DSM_EQ_BQ5_B1_BYTE1 (0x217E) DSM_EQ_BQ5_B1_BYTE2 (0x217F) DSM_EQ_BQ5_B2_BYTE0 (0x2181) DSM_EQ_BQ5_B2_BYTE1 (0x2182) DSM_EQ_BQ5_B2_BYTE2 (0x2183) DSM_EQ_BQ5_A1_BYTE0 (0x2185) DSM_EQ_BQ5_A1_BYTE1 (0x2186) DSM_EQ_BQ5_A1_BYTE2 (0x2187) DSM_EQ_BQ5_A2_BYTE0 (0x2189) DSM_EQ_BQ5_A2_BYTE1 (0x218A) DSM_EQ_BQ5_A2_BYTE2 (0x218B) DSM_EQ_BQ6_B0_BYTE0 (0x218D) DSM_EQ_BQ6_B0_BYTE1 (0x218E) DSM_EQ_BQ6_B0_BYTE2 (0x218F) DSM_EQ_BQ6_B1_BYTE0 (0x2191) DSM_EQ_BQ6_B1_BYTE1 (0x2192) DSM_EQ_BQ6_B1_BYTE2 (0x2193) DSM_EQ_BQ6_B2_BYTE0 (0x2195) DSM_EQ_BQ6_B2_BYTE1 (0x2196) DSM_EQ_BQ6_B2_BYTE2 (0x2197) DSM_EQ_BQ6_A1_BYTE0 (0x2199) DSM_EQ_BQ6_A1_BYTE1 (0x219A) DSM_EQ_BQ6_A1_BYTE2 (0x219B) DSM_EQ_BQ6_A2_BYTE0 (0x219D) DSM_EQ_BQ6_A2_BYTE1 (0x219E) DSM_EQ_BQ6_A2_BYTE2 (0x219F) DSM_EQ_BQ7_B0_BYTE0 (0x21A1) DSM_EQ_BQ7_B0_BYTE1 (0x21A2) DSM_EQ_BQ7_B0_BYTE2 (0x21A3) DSM_EQ_BQ7_B1_BYTE0 (0x21A5) DSM_EQ_BQ7_B1_BYTE1 (0x21A6) DSM_EQ_BQ7_B1_BYTE2 (0x21A7) DSM_EQ_BQ7_B2_BYTE0 (0x21A9) DSM_EQ_BQ7_B2_BYTE1 (0x21AA) DSM_EQ_BQ7_B2_BYTE2 (0x21AB) DSM_EQ_BQ7_A1_BYTE0 (0x21AD) DSM_EQ_BQ7_A1_BYTE1 (0x21AE) DSM_EQ_BQ7_A1_BYTE2 (0x21AF) DSM_EQ_BQ7_A2_BYTE0 (0x21B1) DSM_EQ_BQ7_A2_BYTE1 (0x21B2) DSM_EQ_BQ7_A2_BYTE2 (0x21B3) DSM_EQ_BQ8_B0_BYTE0 (0x21B5) DSM_EQ_BQ8_B0_BYTE1 (0x21B6) DSM_EQ_BQ8_B0_BYTE2 (0x21B7) DSM_EQ_BQ8_B1_BYTE0 (0x21B9) DSM_EQ_BQ8_B1_BYTE1 (0x21BA) DSM_EQ_BQ8_B1_BYTE2 (0x21BB) DSM_EQ_BQ8_B2_BYTE0 (0x21BD) DSM_EQ_BQ8_B2_BYTE1 (0x21BE) DSM_EQ_BQ8_B2_BYTE2 (0x21BF) DSM_EQ_BQ8_A1_BYTE0 (0x21C1) DSM_EQ_BQ8_A1_BYTE1 (0x21C2) DSM_EQ_BQ8_A1_BYTE2 (0x21C3) DSM_EQ_BQ8_A2_BYTE0 (0x21C5) DSM_EQ_BQ8_A2_BYTE1 (0x21C6) DSM_EQ_BQ8_A2_BYTE2 (0x21C7) DSMIG WB DRC RELEASE TIME 1 (0x2380) DSMIG WB DRC RELEASE TIME 2 (0x2381) DSMIG WB DRC ATTACK TIME 1 (0x2382) DSMIG WB DRC ATTACK TIME 2 (0x2383) DSMIG WB DRC COMPRESSION RATIO (0x2384) DSMIG WB DRC COMPRESSION THRESHOLD (0x2385) DSMIG WB DRC MAKEUPGAIN (0x2386) DSMIG WB DRC NOISE GATE THRESHOLD (0x2387) DSMIG WBDRC HPF ENABLE (0x2388) DSMIG PPR THRESHOLD (0x238B) DSM TPROT THRESHOLD BYTE 0 (0x238E) DSM TPROT THRESHOLD BYTE 1 (0x238F) DSM TPROT ROOM TEMPERATURE BYTE0 (0x2390) DSM TPROT ROOM TEMPERATURE BYTE 1 (0x2391) DSM TPROT RECIP RDC ROOM BYTE0 (0x2392) DSM TPROT RECIP RDC ROOM BYTE1 (0x2393) DSM TPROT RECIP RDC ROOM BYTE2 (0x2394) DSM TPROT RECIP TCONST BYTE0 (0x2395) DSM TPROT RECIP TCONST BYTE1 (0x2396) DSM TPROT RECIP TCONST BYTE2 (0x2397) DSM TPROT ATTENUATION SETTINGS (0x2398) DSM TPROT PG TEMP THRESH BYTE0 (0x239A) DSM TPROT PG TEMP THRESH BYTE1 (0x239B) THERMAL RESISTANCE RD BACK BYTE1 (0x239C) THERMAL RESISTANCE RD BACK BYTE0 (0x239D) DSMIG EXCURSION PROTECTION RELEASE TIME BYTE 0 (0x23A4) DSMIG EXCURSION PROTECTION RELEASE TIME BYTE 1 (0x23A5) DSMIG EXCURSION PROTECTION THRESHOLD (0x23A6) DSMIG EXCURSION PROTECTION DEL BUFFER (0x23A7) DSMIG DEBUZZER THRESHOLD (0x23B5) DSM VOL ENA (0x23B9) DSM_VOL_CTRL (0x23BA) DSMIG ENABLES (0x23E0) DSP GLOBAL ENABLE (0x23E1) DSM_THERMAL_GAIN (0x23F0) DSM_PPR_GAIN (0x23F1) DSM_DBZ_GAIN (0x23F2) DSM_WBDRC_GAIN (0x23F3) GLOBAL ENABLE (0x23FF) REV ID (0x24FF) Applications Information Boost Converter Component Selection Battery Input Capacitor Selection Boost Inductor Selection (L1) Power Amplifier Supply Bypass Capacitors (CPVDD) Boost Converter Settings Startup Sequence Shutdown Sequence Recommended External Components Typical Application Circuit MAX98390 Ordering Information Revision History
