Datasheet S-19213 (ABLIC) - 7
ManufacturerABLIC
DescriptionAutomotive, 125°C Operation, 36 V Input, 500 mA Voltage Regulator
Pages / Page46 / 7 — AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 500 mA VOLTAGE REGULATOR. …
File Format / SizePDF / 773 Kb
AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 500 mA VOLTAGE REGULATOR. S-19213 Series. Absolute Maximum Ratings. Table 7
AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 500 mA VOLTAGE REGULATOR S-19213 Series Absolute Maximum Ratings Table 7
Rev.1.1_00
(Ta = +25°C unless otherwise specified) Item Symbol Absolute Maximum Rating Unit VIN VSS − 0.3 to VSS + 45 V Input voltage VON / OFF VSS − 0.3 to VIN + 0.3 ≤ VSS + 45 V VVADJ VSS − 0.3 to VIN + 0.3 ≤ VSS + 45 V Output voltage VOUT VSS − 0.3 to VIN + 0.3 ≤ VSS + 45 V Output current IOUT 650 mA Junction temperature Tj −40 to +150 °C Operation ambient temperature Topr −40 to +125 °C Storage temperature Tstg −40 to +150 °C
Caution The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions. Thermal Resistance Value Table 8
Item Symbol Condition Min. Typ. Max. Unit Board A − 70 − °C/W Board B − − − °C/W TO-252-5S(A) Board C − − − °C/W Board D − − − °C/W Board E − 18 − °C/W Junction-to-ambient thermal resistance
*1, *2
θJA Board A − 86 − °C/W Board B − − − °C/W HSOP-8A Board C − − − °C/W (under development) Board D − − − °C/W Board E − 19 − °C/W
*1.
Test environment: compliance with JEDEC STANDARD JESD51-2A
*2.
Measurement values when this IC is mounted on each board
Remark
Refer to "
Power Dissipation
" and "
Test Board
" for details. 7
