Datasheet S-19214 (ABLIC) - 8
ManufacturerABLIC
DescriptionAutomotive, 125°C Operation, 36 V Input, 1000 mA Voltage Regulator
Pages / Page46 / 8 — AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 1000 mA VOLTAGE REGULATOR …
File Format / SizePDF / 812 Kb
AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 1000 mA VOLTAGE REGULATOR S-19214 Series. Electrical Characteristics
AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 1000 mA VOLTAGE REGULATOR S-19214 Series Electrical Characteristics
Rev.1.1_00
Electrical Characteristics 1. Type in which output voltage is internally set Table 9
(Tj = −40°C to +125°C unless otherwise specified) Test Item Symbol Condition Min. Typ. Max. Unit Circuit VIN = 13.5 V, VOUT(S) = 1.8 V, 3.0 V, 3.3 V, VOUT(S) V V OUT(S) V 1 I 5.0 V, 8.0 V, 12.0 V − 1.5% OUT(S) + 1.5% Output voltage
*1
V OUT = 10 mA OUT(E) VOUT(S) + 1.0 V ≤ VIN ≤ 18.0 V, VOUT(S) V V OUT(S) V 1 1 mA ≤ I OUT(S) OUT ≤ 200 mA −1.8% + 1.8% Output current
*2
IOUT VOUT(S) + 2.0 V ≤ VIN 1000
*4
− − mA 3 VOUT(S) = 1.8 V −
*5
− V 1 I Dropout voltage
*3
V OUT = 200 mA, drop V Ta = +25°C OUT(S) = 3.0 V, 3.3 V − 0.16 0.32 V 1 VOUT(S) = 5.0 V, 8.0 V, 12.0 V − 0.13 0.22 V 1 ΔV Line regulation OUT1 Δ V VOUT(S) + 1.0 V ≤ VIN ≤ 28.0 V, IOUT = 10 mA − 0.015 0.03 %/V 1 IN • VOUT VOUT(S) = 1.8 V, 3.0 V, 3.3 V − 15 30 mV 1 VIN = VOUT(S) + 1.0 V, VOUT(S) = 5.0 V − 20 40 mV 1 Load regulation ΔVOUT2 1 mA ≤ IOUT ≤ 300 mA, V Ta = +25°C OUT(S) = 8.0 V − 35 70 mV 1 VOUT(S) = 12.0 V − 45 90 mV 1 Current consumption I during operation SS1 VIN = 13.5 V, IOUT = 10 μA, ON / OFF pin = ON − 5.0 9.8 μA 2 Current consumption I during power-off SS2 VIN = 13.5 V, no load, ON / OFF pin = OFF − 0.1 2.0 μA 2 Input voltage VIN − 2.8 − 36.0 V − ON / OFF pin V V IN = 13.5 V, RL = 1.0 kΩ, 2.0 − − V 4 input voltage "H" SH determined by VOUT output level ON / OFF pin V V IN = 13.5 V, RL = 1.0 kΩ, − − 0.8 V 4 input voltage "L" SL determined by VOUT output level ON / OFF pin I input current "H" SH VIN = 13.5 V, VON / OFF = VIN −0.1 0.3 1.0 μA 4 ON / OFF pin I input current "L" SL VIN = 13.5 V, VON / OFF = 0 V −0.1 − 0.1 μA 4 VIN = 13.5 V, f = 100 Hz, VOUT(S) = 1.8 V, 3.0 V, 3.3 V, 5.0 V − 60 − dB 5 Ripple rejection |RR| ΔVrip = 0.5 Vrms, IOUT = 100 mA, VOUT(S) = 8.0 V, 12.0 V − 50 − dB 5 Ta = +25°C V Short-circuit current I IN = VOUT(S) + 1.0 V, ON / OFF pin = ON, short − 250 − mA 3 VOUT = 0 V, Ta = +25°C Thermal shutdown T detection temperature SD Junction temperature − 170 − °C − Thermal shutdown T release temperature SR Junction temperature − 135 − °C − Discharge shunt resistance R during power-off LOW VIN = 13.5 V, VOUT = 0.1 V, ON / OFF pin = OFF − 3.0 − kΩ 6 8
