Datasheet for Industrial R1540x-Y (Ricoh) - 5
ManufacturerRicoh
DescriptionHigh Noise Immunity 42 V Input Voltage 70 mA Voltage Tracker for Industrial Applications
Pages / Page24 / 5 — R1540x-Y. ABSOLUTE MAXIMUM RATINGS. Symbol. Parameter. Rating. Unit. …
R1540x-Y. ABSOLUTE MAXIMUM RATINGS. Symbol. Parameter. Rating. Unit. RECOMMENDED OPERATING CONDITIONS
R1540x-Y ABSOLUTE MAXIMUM RATINGS Symbol Parameter Rating Unit RECOMMENDED OPERATING CONDITIONS
R1540x-Y
NO.EY-513-190411
Input Voltage −0.3 to 50 V VIN Peak Voltage (1) 60 V VCE/ADJ CE/ADJ Pin Input Voltage −0.3 to 50 V VOUT VOUT Pin Output Voltage −0.3 to VIN + 0.3 ≤ 50 V IOUT Output Current 95 mA Power Dissipation (2) SOT-23-5 830 PD mW JEDEC STD. 51 HSOP-8E 3600 Tj Junction Temperature Range −40 to 150 °C Tstg Storage Temperature Range −55 to 150 °C
Electronic and mechanical stress momentarily exceeded absolute maximum ratings may cause permanent damage and may degrade the life time and safety for both device and system using the device in the field. The functional operation at or over these absolute maximum ratings are not assured.
RECOMMENDED OPERATING CONDITIONS Symbol Parameter Rating Unit
VIN Input Voltage 3.5 to 42 V VCE/ADJ CE/ADJ Input Pin Voltage 0 to 14 V Ta Operating Temperature Range −40 to 125 °C
RECOMMENDED OPERATING CONDITONS
All of electronic equipment should be designed that the mounted semiconductor devices operate within the recommended operating conditions. The semiconductor devices cannot operate normally over the recommended operating conditions, even if they are used over such ratings by momentary electronic noise or surge. And the semiconductor devices may receive serious damage when they continue to operate over the recommended operating conditions. (1) Duration time: 200 ms. (2) Refer to POWER DISSIPIATION for detailed information 5
