Datasheet MAX25600 (Maxim) - 3
ManufacturerMaxim
DescriptionSynchronous High Voltage 4 Switch Buck Boost LED Controller
Pages / Page24 / 3 — Electrical Characteristics. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX …
Electrical Characteristics. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX UNITS. SUPPLY VOLTAGE. UNDERVOLTAGE LOCKOUT. VCC REGULATOR
Electrical Characteristics PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS SUPPLY VOLTAGE UNDERVOLTAGE LOCKOUT VCC REGULATOR
MAX25600 Synchronous High-Voltage Four-Switch Buck- Boost LED Controller
(VIN = 12V, VUVEN = 12V, limits are 100% tested at TA = +25°C and TA = +125°C. Limits over the operating temperature range and relevant supply-voltage range are guaranteed by design and characterization.)
INP Input Voltage Range VINP 5.0 60 V Supply Current IINQ No switching 3 6 mA
Undervoltage Lockout Rising VUVEN_THR VUVEN rising 1.12 1.24 1.37 V Hysteresis 106 mV Shutdown Current ISHTDN VUVEN = 0, VIN = 12V 6 20 µA
VCC REGULATOR
5.5V < VIN < 65V; IVCC = 1mA 4.9 5.0 5.1 Output Voltage VCC IVCC = 30mA, 5.5V < VIN < 36V 4.9 5.0 5.1 V IVCC = 1mA to 60mA, 6V < VIN < 25V 4.9 5.0 5.1 Dropout Voltage VCC_DROP VIN = 4.5V, IVCC = 5mA 60 110 mV VCC UVLO Rising VCC_UVLOR Rising 4.0 V VCC UVLO Falling VCC_UVLOF Falling 3.75 V Short-Circuit Current Limit IVCC_SC 70 mA
INPUT CURRENT-SENSE AMPLIFIER
Input Current-Sense Common-Mode Range 5 60 V Input Current-Sense Threshold 3V < VINP < 60V 88 100 112 mV INP Bias Current VINP - VINN = 100mV, VINP = 60V 50 µA INN Bias Current VINP - VINN = 100mV, VINP = 60V 10 µA
ANALOG DIMMING
ICTRL Control Input Voltage Range ICTRLRNG 0.2 1.2 V ICTRL Zero Current Threshold ICTRLZC_VTH (VISP - VISN) < 5mV 0.16 0.18 0.2 V ICTRL Clamp Voltage ICTRLCLMP ICTRL sink = 1µA 1.25 1.30 1.35 V ICTRL Input Bias Current ICTRLIIN VICTRL = 0 to 5.0V 20 500 mA
LED CURRENT-SENSE AMPLIFIER
Common-Mode Input Range -0.3 +60 V Differential Signal Range 0 200 mV ISN Input Bias Current IBISN VISP - VISN = 200mV, VISP = 60V 22 60 µA ISP Input Bias Current IBISP VISP - VISN = 200mV, VISP = 60V 350 550 µA Voltage Gain VISP - VISN) = 200mV, 3V < VISP, VISN < 60V 4.9 5.00 5.1 V/V www.maximintegrated.com Maxim Integrated │ 3
