Datasheet LA4555 (Sanyo) - 3
ManufacturerSanyo
Description2-Channel AF Power Amplifier for Radio, Tape Recorder Use
Pages / Page10 / 3 — LA4555. Sample Printed Circuit Pattern. Sample Application Circuit :. …
File Format / SizePDF / 354 Kb
LA4555. Sample Printed Circuit Pattern. Sample Application Circuit :. Description of External Parts
LA4555 Sample Printed Circuit Pattern Sample Application Circuit : Description of External Parts
(Cu-foiled side)
Bridge Amplifier Use 1
Bridge Amplifier Use 2
C1 (C2) : Feedback capacitor. The low cutoff frequency is determined by the following formula. 1 fL : Low cutoff frequency fL= 2πC1Rf Rf : Feedback resistance Since this capacitor as well as decoupling capacitor affects the starting time, the capacitor value must be fixed with the necessary low frequency band fully considered. C3 (C4) : Bootstrap capacitor. The output at low frequencies depends on this capacitor. Decreasing the capacitor value lowers the output at low frequencies. A capacitor value of 47µF or more is required. C5 (C6) : Oscillation blocking capacitor. Use a polyester film capacitor that is good in high frequency response and temperature characteristic. The use of an electrolytic capacitor, ceramic capacitor may cause oscillation to occur at low temperatures. Continued on next page. No.1697–3/10
