Datasheet LA4183 (Sanyo) - 5
ManufacturerSanyo
Description2.3 W 2-Channel AF Power Amplifier for Radio Cassette Players
Pages / Page12 / 5 — LA4183
File Format / SizePDF / 317 Kb
LA4183
LA4183
LA4183
The output of ch1 is divided with R5, R6 and led to pin 1 and then inputted to ch2. Since the attenuation degree (R5/R6) of ch1 output and the amplification degree (R4/R2 + R6)) of ch2 are fixed at an equal value, the ch2 output is in opposite phase with the ch1 output. Therefore, the total voltage gain gets apparently 6 dB higher than the voltage gain of ch1 alone and is determined by the following equation. R3 VG = 20 log + 6 [dB] R1 If the IC is used at a voltage gain less than this, the following equation with Rf added applies. R3 VG = 20 log + 6 [dB] R1 + Rf 2. Starting time Starting time depends on capacitance of C1 (C2) and C9 as shown in the diagram below. That is because of using a muting circuit utilizing the C9 (decoupling capacitor) time constant for pop noise prevention when power is turned on and charging circuits for C1 and C2 (NF capacitors). Quiescent Dependence on C9 Quiescent Dependence on C1 (C2) 3. Crosstalk Channel separation characteristic is important for single-package IC embodying two channels. With LA4183, good channel separation is obtainable even as is, but if the BTL OUT pin (pin 1) is not grounded, it will invite imbalance in crosstalk between the two channels. (Refer to the characteristics diagram.) No.887-5/12
