Datasheet STNRGPF12 (STMicroelectronics) - 4
Description2-channel interleaved PFC driver with embedded digital inrush current limiter function
Pages / Page47 / 4 — List of tables. STNRGPF12
File Format / SizePDF / 995 Kb
List of tables STNRGPF12
link to page 1 link to page 25 link to page 27 link to page 30 link to page 30 link to page 30 link to page 31 link to page 31 link to page 32 link to page 33 link to page 34 link to page 34 link to page 38 link to page 38 link to page 39 link to page 39 link to page 40 link to page 41 link to page 43 link to page 45 link to page 46
List of tables STNRGPF12 List of tables
Table 1. Device summary . 1 Table 2. Pin description . 25 Table 3. Legend of the pins . 27 Table 4. Voltage characteristics . 30 Table 5. Current characteristics . 30 Table 6. Thermal characteristics. 30 Table 7. General operating conditions . 31 Table 8. Operating conditions at power-up/power-down . 31 Table 9. Supply current characteristics. 32 Table 10. Flash program memory/data E2PROM . 33 Table 11. Voltage DC characteristics . 34 Table 12. Current DC characteristics . 34 Table 13. NRST pin characteristics . 38 Table 14. Measurement pin characteristics . 38 Table 15. Analog comparator characteristics . 39 Table 16. ESD absolute maximum ratings . 39 Table 17. Electrical sensitivity. 40 Table 18. Package thermal characteristics . 41 Table 19. TSSOP38 package mechanical data . 43 Table 20. Ordering information . 45 Table 21. Document history . 46 4/47 DS12895 Rev 1 Document Outline Table 1. Device summary List of tables List of figures Documentation 1 General description 1.1 Inrush current limiter function description 1.1.1 Inrush current limiter function with resistive element Figure 1. Inrush current limiter with resistor in series to output capacitor 1.1.2 Inrush current limiter function with controlled bridge Figure 2. Inrush current limiter with controlled rectifier bridge 2 STNRGPF12 control architecture Figure 3. STNRGPF12 control scheme 3 STNRGPF12 block diagram Figure 4. STNRGPF12 block diagram 3.1 Voltage and current loops Figure 5. Voltage loop and current reference 3.2 Measurements section 3.2.1 AC input voltage measurement Figure 6. Vin, measurement 3.2.2 Ambient temperature measurements Figure 7. Temperature measurement 3.2.3 Output current measurement 3.2.4 Output voltage sensing Figure 8. Iout and Vout measurement 3.2.5 Channel current measurement Figure 9. Channel current measurement 3.3 Analog comparators section Figure 10. Analog comparators section 3.4 Driving & Interleaving Figure 11. Driving & interleaving 3.5 Programming section Figure 12. Programming section 3.6 Status indicator Figure 13. Status indicator 3.7 Startup & inrush current limiter function Figure 14. Start-up sequence 3.7.1 Inrush current limiter function Figure 15. Inrush current limiter function with limiter resistor and bypass relay Figure 16. Digital inrush current limiter function with a semi-controlled input bridge Figure 17. Digital inrush current limiter function: sequence of driving of the SCR 3.7.2 PFC soft power-ON Figure 18. Running mode or burst mode 3.8 Fan control Figure 19. Fan Control function 4 Pinout and pin description 4.1 Pinout Figure 20. STNRGPF12 - TSSOP38 pinout 4.2 Pin description Table 2. Pin description (continued) Table 3. Legend of the pins 4.3 Input/output specification 5 Electrical characteristics 5.1 Parameter conditions 5.1.1 Minimum and maximum values 5.1.2 Typical values 5.1.3 Typical curves 5.1.4 Typical current consumption Figure 21. Supply current measurement conditions 5.1.5 Loading capacitors Figure 22. Pin loading conditions 5.1.6 Pin output voltage Figure 23. Pin input voltage 5.2 Absolute maximum ratings Table 4. Voltage characteristics Table 5. Current characteristics Table 6. Thermal characteristics 5.3 Operating conditions Table 7. General operating conditions Table 8. Operating conditions at power-up/power-down 5.3.1 VOUT external capacitor Figure 24. External capacitor CVOUT 5.3.2 Supply current characteristics Table 9. Supply current characteristics 5.3.3 Memory characteristics Table 10. Flash program memory/data E2PROM 5.3.4 Input/output specifications 5.3.5 I/O port pin characteristics Table 11. Voltage DC characteristics Table 12. Current DC characteristics 5.3.6 Typical output level curves Figure 25. VOH normal pin Figure 26. VOL normal pin Figure 27. VOH fast I/Os pins Figure 28. VOL fast I/Os pins Figure 29. VOH CLOCK pin Figure 30. VOL CLOCK pin 5.3.7 Reset pin characteristics Table 13. NRST pin characteristics 5.4 Analog input characteristics 5.4.1 Measurement section Table 14. Measurement pin characteristics 5.4.2 Analog section Table 15. Analog comparator characteristics 5.5 EMC characteristics 5.5.1 Electrostatic discharge (ESD) Table 16. ESD absolute maximum ratings 5.5.2 Static latch-up Table 17. Electrical sensitivity 6 Thermal data Table 18. Package thermal characteristics 7 Package information 7.1 TSSOP38 package information Figure 31. TSSOP38 package outline Table 19. TSSOP38 package mechanical data 8 STNRGPF12 development tools 9 Ordering information Table 20. Ordering information 10 Revision history Table 21. Document history
