Datasheet TB9062FNG (Toshiba) - 5
Manufacturer | Toshiba |
Description | Pre-driver for automobile |
Pages / Page | 30 / 5 — TB9062FNG. IN/. I/O. Pin. Name. Description. Notes. OUT. voltage. Test. … |
File Format / Size | PDF / 871 Kb |
TB9062FNG. IN/. I/O. Pin. Name. Description. Notes. OUT. voltage. Test. pin. 10kΩ. 10. TEST. IN. 5V. (short. to. GND. on. PCB). Pull. down. Test. pin. 11. OTEST. OUT. 5V. -
TB9062FNG IN/ I/O Pin Name Description Notes OUT voltage Test pin 10kΩ 10 TEST IN 5V (short to GND on PCB) Pull down Test pin 11 OTEST OUT 5V - (short to GND on PCB) Pre-driver output enable 100kΩ 12 INH ・INH=H:pre-driver OFF(Hi-Z) IN 5V Pull down ・INH=L:normal operation 13 SHUNT_U External shunt R connection pin for motor over current detection IN 5V - 14 WAVEUVW Motor EMF zero cross detection pin for motor position detection IN VBAT - 15 GNDA Ground pin for small signal line - - - 16 GNDP Ground pin for power line - - - 17 OUT_UN Output for U phase Nch MOSFET OUT VBAT - 18 OUT_VN Output for V phase Nch MOSFET OUT VBAT - 19 OUT_WN Output for W phase Nch MOSFET OUT VBAT - 20 COMP_IN Ref. voltage input for detecting motor EMF zero cross detection IN VBAT - 21 OUT_UP Output for U phase Pch MOSFET OUT VBAT - 22 OUT_VP Output for V phase Pch MOSFET OUT VBAT - 23 OUT_WP Output for W phase Pch MOSFET OUT VBAT - 24 VBAT Battery power supply IN VBAT - 【Caution】 *1:Improper pin connection may cause faults in motor protection, unstable operation or to stop altogether. *2:Adjacent pin short may cause damage to the IC or entire system. *3:Improper mounting may cause damage to the IC or entire system. © 2019 5 / 30 Toshiba Electronic Devices & Storage Corporation 2019-08-05
