Datasheet MB85AS8MT (Fujitsu) - 9
ManufacturerFujitsu
DescriptionMemory ReRAM 8M (1024 K x 8) Bit SPI
Pages / Page31 / 9 — MB85AS8MT. RDSR. WRSR
MB85AS8MT RDSR WRSR
MB85AS8MT RDSR
The RDSR command reads status register data. After op-code of RDSR is input to SI, 8-cycle clock is input to SCK. The SI value is invalid for this time. SO is output synchronously to a falling edge of SCK. In the RDSR command, repeated reading of status register is enabled by sending SCK continuously before rising of CS. CS 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 SCK SI 0 0 0 0 0 1 0 1 Invalid Data Out High-Z SO Invalid MSB LSB
WRSR
The WRSR command writes data to the nonvolatile memory bit of status register. After performing WRSR op-code to a SI pin, 8 bits writing data is input. WEL (Write Enable Latch) is not able to be written with WRSR command. A SI value correspondent to bit 1 is ignored. Bit 0 of the status register cannot be written. The SI value corresponding to bit 0 is ignored. WP signal level shall be fixed before performing WRSR command, and do not change the WP signal level until the end of command sequence. After rising edge of CS, MB85AS8MT starts writing operation to nonvolatile register and set WIP bit in status register to “1”. After this writing operation has finished, reset this WIP bit from “1” to “0”. Although the RDSR command is executable for WIP polling during this writing process, any other commands will not be performed. CS 0 1 2 3 4 5 6 7 0 1 2 3 4 5 6 7 SCK Instruction Data In SI 0 0 0 0 0 0 0 1 7 6 5 4 3 2 1 0 MSB LSB High-Z SO DS501-00060-1v0-E 9 Document Outline DESCRIPTION FEATURES PIN ASSIGNMENT PIN FUNCTIONAL DESCRIPTIONS BLOCK DIAGRAM SPI MODE SERIAL PERIPHERAL INTERFACE (SPI) STATUS REGISTER OP-CODE COMMAND WRITING OPERATION OF NONVOLATILE MEMORY 1. Address counter control 2. WIP polling BLOCK PROTECT WRITING PROTECT HOLD OPERATION (available only for SOP package) ABSOLUTE MAXIMUM RATINGS RECOMMENDED OPERATING CONDITIONS ELECTRICAL CHARACTERISTICS 1. DC Characteristics 2. AC Characteristics 3. Pin Capacitance TIMING DIAGRAM POWER ON/OFF SEQUENCE ReRAM CHARACTERISTICS ESD AND LATCH-UP MB85AS8MTPF (8-pin plastic SOP) REFLOW CONDITIONS AND FLOOR LIFE CURRENT STATUS ON CONTAINED RESTRICTED SUBSTANCES ORDERING INFORMATION PACKAGE DIMENSION MARKING (11-pin WLP) MARKING (8-pin SOP) PACKING FIGURE 1. Emboss carrier tape and package direction of storage 2. Reel EMBOSS CARRIER TAPE DRAWING
