Datasheet HT45F5Q-3 (Holtek) - 6
ManufacturerHoltek
DescriptionBattery Charger Flash MCU
Pages / Page163 / 6 — HT45F5Q-3. Battery Charger Flash MCU. Features. CPU Features. Peripheral …
File Format / SizePDF / 2.7 Mb
HT45F5Q-3. Battery Charger Flash MCU. Features. CPU Features. Peripheral Features
HT45F5Q-3 Battery Charger Flash MCU Features CPU Features Peripheral Features
HT45F5Q-3 HT45F5Q-3 Battery Charger Flash MCU Battery Charger Flash MCU Features CPU Features
• Operating voltage ♦ fSYS= 8MHz: 2.2V~5.5V • Up to 0.5μs instruction cycle with 8MHz system clock at VDD=5V • Power down and wake-up functions to reduce power consumption • Oscillator types ♦ Internal High Speed 8MHz RC – HIRC ♦ Internal Low Speed 32kHz RC – LIRC • Multi-mode operation: FAST, SLOW, IDLE and SLEEP • Fully integrated internal high speed and low speed RC oscillators require no external components • All instructions executed in one or two instruction cycles • Table read instructions • 63 powerful instructions • 6-level subroutine nesting • Bit manipulation instruction
Peripheral Features
• Flash Program Memory: 4K×15 • RAM Data Memory: 256×8 • Emulated EEPROM Memory: 32×15 • Watchdog Timer function • 23 bidirectional I/O lines • Two pin-shared external interrupts • Multiple Timer Modules for time measurement, input capture, compare match output or PWM output or single pulse output function • Universal Serial Interface Module – USIM for SPI, I2C or UART communication • Dual Time-Base functions for generation of fixed time interrupt signals • 10 external channels 12-bit resolution A/D converter • Battery charger circuit ♦ 14-bit D/A Converter and OPA0 are used for constant current control ♦ 12-bit D/A Converter and OPA1 are used for constant voltage control ♦ OPA2 is 20 times amplifier for current sense • Software controlled 4-SCOM lines LCD driver with 1/2 bias • 16-bit Cyclic Redundancy Check Unit • Low voltage reset function • Package types: 24/28-pin SSOP Rev. 1.00 6 July 31, 2019 Rev. 1.00 7 July 31, 2019 Document Outline Features CPU Features Peripheral Features General Description Block Diagram Pin Assignment Pin Description Absolute Maximum Ratings D.C. Characteristics Operating Voltage Characteristics Operating Current Characteristics Standby Current Characteristics A.C. Characteristics High Speed Internal Oscillator – HIRC – Frequency Accuracy Low Speed Internal Oscillator Characteristics – LIRC Operating Frequency Characteristic Curves System Start Up Time Characteristics Input/Output Characteristics Memory Characteristics LVR Electrical Characteristics A/D Converter Electrical Characteristics D/A Converter Electrical Characteristics Operational Amplifier Electrical Characteristics Software Controlled LCD Driver Electrical Characteristics Power-on Reset Characteristics System Architecture Clocking and Pipelining Program Counter Stack Arithmetic and Logic Unit – ALU Flash Program Memory Structure Special Vectors Look-up Table Table Program Example In Circuit Programming – ICP On-Chip Debug Support – OCDS Data Memory Structure General Purpose Data Memory Special Purpose Data Memory Special Function Register Description Indirect Addressing Registers – IAR0, IAR1 Memory Pointers – MP0, MP1 Bank Pointer – BP Accumulator – ACC Program Counter Low Register – PCL Look-up Table Registers – TBLP, TBHP, TBLH Status Register – STATUS Emulated EEPROM Data Memory Emulated EEPROM Data Memory Structure Emulated EEPROM Registers Erasing the Emulated EEPROM Writing Data to the Emulated EEPROM Reading Data from the Emulated EEPROM Programming Considerations Oscillators Oscillator Overview System Clock Configurations Internal High Speed RC Oscillator – HIRC Internal 32kHz Oscillator – LIRC Operating Modes and System Clocks System Clocks System Operation Modes Control Registers Operating Mode Switching Standby Current Considerations Wake-up Watchdog Timer Watchdog Timer Clock Source Watchdog Timer Control Register Watchdog Timer Operation Reset and Initialisation Reset Functions Reset Initial Conditions Input/Output Ports Pull-high Resistors Port A Wake-up I/O Port Control Registers Pin-shared Functions I/O Pin Structures READ PORT Function Programming Considerations Timer Modules – TM Introduction TM Operation TM Clock Source TM Interrupts TM External Pins Programming Considerations Compact Type TM – CTM Compact Type TM Operation Compact Type TM Register Description Compact Type TM Operation Modes Standard Type TM – STM Standard TM Operation Standard Type TM Register Description Standard Type TM Operation Modes Analog to Digital Converter A/D Converter Overview A/D Converter Register Description A/D Converter Data Registers – SADOL, SADOH A/D Converter Reference Voltage A/D Converter Input Signal A/D Converter Operation Conversion Rate and Timing Diagram Summary of A/D Conversion Steps Programming Considerations A/D Conversion Function A/D Conversion Programming Examples Battery Charge Module Battery Charge Module Registers Digital to Analog Converter Operational Amplifiers Universal Serial Interface Module – USIM SPI Interface I2C Interface UART Interface Software Controlled LCD Driver LCD Operation LCD Bias Current Control Cyclic Redundancy Check – CRC CRC Registers CRC Operation Interrupts Interrupt Registers Interrupt Operation External Interrupts Time Base Interrupts Multi-function Interrupts TM Interrupts A/D Converter Interrupt USIM Interrupt Interrupt Wake-up Function Programming Considerations Application Descriptions Introduction Functional Description Hardware Circuit Instruction Set Introduction Instruction Timing Moving and Transferring Data Arithmetic Operations Logical and Rotate Operation Branches and Control Transfer Bit Operations Table Read Operations Other Operations Instruction Set Summary Table Conventions Instruction Definition Package Information 24-pin SSOP (150mil) Outline Dimensions 28-pin SSOP (150mil) Outline Dimensions
