Datasheet ADP5073 (Analog Devices)
Description | 1.2 A, DC-to-DC Inverting Regulator |
Pages / Page | 17 / 1 — 1.2 A, DC-to-DC Inverting Regulator. Data Sheet. ADP5073. FEATURES. … |
Revision | A |
File Format / Size | PDF / 514 Kb |
1.2 A, DC-to-DC Inverting Regulator. Data Sheet. ADP5073. FEATURES. TYPICAL APPLICATION CIRCUIT
1.2 A, DC-to-DC Inverting Regulator Data Sheet ADP5073 FEATURES TYPICAL APPLICATION CIRCUIT Wide input voltage range: 2.85 V to 15 V CVREF Adjustable negative output to VIN − 39 V AVIN VREF Integrated 1.2 A main switch VIN PVIN R 1.2 MHz/2.4 MHz switching frequency with optional external FB CIN frequency synchronization from 1.0 MHz to 2.6 MHz ADP5073 FB RFT Resistor programmable soft start timer ON OFF EN Slew rate control for lower system noise SW V C OUT VREG D1 C Precision enable control VREG OUT L1 Power-good output R SS PG UVLO, OCP, OVP, and TSD protection PWRGD PWRGD 3 mm × 3 mm, 16-lead LFCSP SLEW C −40°C to +125°C junction temperature C COMP SYNC/FREQ Supported by the ADIsimPower t ool set RC GND
001
12817- Figure 1.
Bipolar amplifiers, ADCs, digital-to-analog converters (DACs), and multiplexers High speed converters Radio frequency (RF) power amplifier (PA) bias Optical modules GENERAL DESCRIPTION
The ADP5073 is a high performance dc-to-dc inverting regulator Other key safety features in the ADP5073 include overcurrent used to generate negative supply rails. protection (OCP), overvoltage protection (OVP), thermal The input voltage range of 2.85 V to 15 V supports a wide variety of shutdown (TSD), and input undervoltage lockout (UVLO). applications. The integrated main switch enables the generation of The ADP5073 is available in a 16-lead LFCSP and is rated for a an adjustable negative output voltage down to 39 V below the −40°C to +125°C operating junction temperature range. input voltage.
Table 1. Related Devices
The ADP5073 operates at a pin selected 1.2 MHz/2.4 MHz
Boost Inverter
switching frequency. The ADP5073 can synchronize with an
Device Switch (A) Switch (A) Package
external oscil ator from 1.0 MHz to 2.6 MHz to ease noise ADP5070 1.0 0.6 20-lead LFCSP (4 mm × filtering in sensitive applications. The regulator implements 4 mm) and TSSOP programmable slew rate control circuitry for the MOSFET ADP5071 2.0 1.2 20-lead LFCSP (4 mm × driver stage to reduce electromagnetic interference (EMI). 4 mm) and TSSOP The ADP5073 includes a fixed internal or resistor programmable ADP5073 Not 1.2 16-lead LFCSP (3 mm × applicable 3 mm) soft start timer to prevent inrush current at power-up. During ADP5074 Not 2.4 16-lead LFCSP (3 mm × shutdown, the regulator completely disconnects the load from the applicable 3 mm) input supply to provide a true shutdown. A power-good pin is ADP5075 Not 0.8 12-ball WLCSP available to indicate the output is stable. applicable (1.61 mm × 2.18 mm)
Rev. A Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2015–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS TYPICAL APPLICATION CIRCUIT GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION PWM MODE SKIP MODE UNDERVOLTAGE LOCKOUT (UVLO) OSCILLATOR AND SYNCHRONIZATION INTERNAL REGULATORS PRECISION ENABLING SOFT START SLEW RATE CONTROL CURRENT-LIMIT PROTECTION OVERVOLTAGE PROTECTION POWER GOOD THERMAL SHUTDOWN APPLICATIONS INFORMATION ADIsimPOWER DESIGN TOOL COMPONENT SELECTION Feedback Resistors Output Capacitor Input Capacitor VREG Capacitor VREF Capacitor Soft Start Resistor Diodes Inductor Selection Loop Compensation COMMON APPLICATIONS LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
