Datasheet ADP5071 (Analog Devices) - 10 Manufacturer Analog Devices Description 2 A/1.2 A DC-to-DC Switching Regulator with Independent Positive and Negative Outputs Pages / Page 27 / 10 — ADP5071. Data Sheet. 100. NCY. ICI. TA = +125°C. TA = +25°C. TA = –40°C. … Revision E File Format / Size PDF / 1.0 Mb Document Language English
ADP5071. Data Sheet. 100. NCY. ICI. TA = +125°C. TA = +25°C. TA = –40°C. 0.001. 0.01. 0.1. LOAD (A). 0.5. 0.3. INAL. –0.1. N F. ARI. –0.3. VOUT ACCURACY
Model Line for this Datasheet Text Version of Document ADP5071 Data Sheet 100 100 80 80 %) %) ( 60 ( 60 NCY NCY E E ICI ICI F 40 F 40 F F E E 20 20 TA = +125°C TA = +125°C TA = +25°C TA = +25°C TA = –40°C TA = –40°C 0 0 0.001 0.01 0.1 1 0150.001 0.01 0.1 1 018LOAD (A) 12069-LOAD (A) 12069- Figure 16. Boost Regulator Efficiency over Temperature, Figure 19. Inverting Regulator Efficiency over Temperature, VIN = 5 V, VPOS = 15 V, fSW = 1.2 MHz VIN = 5 V, VNEG = −15 V, fSW = 1.2 MHz0.5 0.5 0.3 %) 0.3 %) ( ( INAL INAL M M 0.1 0.1 NO NO M M RO RO –0.1 N F –0.1 N F IO IO AT AT ARI –0.3 ARI V –0.3 V VOUT ACCURACY VOUT ACCURACY VREF ACCURACY VFB1 ACCURACY VFB2 ACCURACY –0.5 –0.5 0 5 10 15 20 0160 5 10 15 20 019VIN (V) V 12069-IN (V) 12069- Figure 17. Boost Regulator Line Regulation, VPOS = 15 V, Figure 20. Inverting Regulator Line Regulation, VNEG = −15 V, fSW = 1.2 MHz, 15 mA Load, TA = 25°C fSW = 1.2 MHz, 15 mA Load, TA = 25°C0.5 0.5 %) %) ( ( B1 B2 F 0.3 F 0.3 N V N V I I E E 0.1 0.1 CHANG CHANG N, N, IO IO –0.1 –0.1 AT AT UL UL G G –0.3 –0.3 AD RE AD RE O O L 1.2MHz L 1.2MHz 2.4MHz 2.4MHz –0.5 –0.5 0 0.1 0.2 0.3 0.4 0.5 0170 0.05 0.10 0.15 020LOAD (A) 12069-LOAD (A) 12069- Figure 18. Boost Regulator Load Regulation, VIN = 5 V, VPOS = 15 V Figure 21. Inverting Regulator Load Regulation, VIN = 5 V, VNEG = −15 V Rev. E | Page 10 of 27 Document Outline Features Applications Typical Application Circuit General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory of Operation PWM Mode PSM Mode Undervoltage Lockout (UVLO) Oscillator and Synchronization Internal Regulators Precision Enabling Soft Start Slew Rate Control Current-Limit Protection Overvoltage Protection Thermal Shutdown Start-Up Sequence Applications Information ADIsimPower Design Tool Component Selection Feedback Resistors Output Capacitors Input Capacitor VREG Capacitor VREF Capacitor Soft Start Resistor Diodes Inductor Selection for the Boost Regulator Inductor Selection for the Inverting Regulator Loop Compensation Boost Regulator Inverting Regulator Common Applications Super Low Noise With Optional LDOs SEPIC Step-Up/Step-Down Operation Layout Considerations Outline Dimensions Ordering Guide
