Datasheet LT3758, LT3758A (Analog Devices) - 2
Description | High Input Voltage, Boost, Flyback, SEPIC and Inverting Controller |
Pages / Page | 38 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION … |
Revision | F |
File Format / Size | PDF / 1.4 Mb |
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
LT3758/LT3758A
VIN, SHDN/UVLO (Note 7) ..100V Operating Junction Temperature Range (Notes 2, 8) INTVCC ..VIN + 0.3V, 20V LT3758E/LT3758AE ... –40°C to 125°C GATE .. INTVCC + 0.3V LT3758I/LT3758AI ... –40°C to 125°C SYNC ..8V LT3758H/LT3758AH .. –40°C to 150°C VC, SS ...3V LT3758MP/LT3758AMP ... –55°C to 150°C RT ... 1.5V Storage Temperature Range SENSE ..±0.3V DFN .. –65°C to 125°C FBX ... –6V to 6V MSOP .. –65°C to 150°C Lead Temperature (Soldering, 10 sec) MSOP ..300°C
PIN CONFIGURATION
TOP VIEW TOP VIEW VC 1 10 VIN VC 1 10 VIN FBX 2 9 SHDN/UVLO FBX 2 9 SHDN/UVLO SS 3 11 8 INTVCC SS 3 11 8 INTVCC RT 4 7 GATE RT 4 7 GATE SYNC 5 6 SENSE SYNC 5 6 SENSE MSE PACKAGE 10-LEAD PLASTIC MSOP DD PACKAGE 10-LEAD (3mm × 3mm) PLASTIC DFN TJMAX = 150°C, θJA = 40°C/W EXPOSED PAD (PIN 11) IS GND, MUST BE SOLDERED TO PCB TJMAX = 125°C, θJA = 43°C/W EXPOSED PAD (PIN 11) IS GND, MUST BE SOLDERED TO PCB
LT3758EDD#PBF LT3758EDD#TRPBF LDNK 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3758IDD#PBF LT3758IDD#TRPBF LDNK 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3758EMSE#PBF LT3758EMSE#TRPBF LTDNM 10-Lead (3mm × 3mm) Plastic MSOP –40°C to 125°C LT3758IMSE #PBF LT3758IMSE#TRPBF LTDNM 10-Lead (3mm × 3mm) Plastic MSOP –40°C to 125°C LT3758HMSE#PBF LT3758HMSE#TRPBF LTDNM 10-Lead (3mm × 3mm) Plastic MSOP –40°C to 150°C LT3758MPMSE #PBF LT3758MPMSE#TRPBF LTDNM 10-Lead (3mm × 3mm) Plastic MSOP –55°C to 150°C LT3758AEDD#PBF LT3758AEDD#TRPBF LGGS 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3758AIDD#PBF LT3758AIDD#TRPBF LGGS 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3758AEMSE#PBF LT3758AEMSE#TRPBF LTGGK 10-Lead (3mm × 3mm) Plastic MSOP –40°C to 125°C LT3758AIMSE#PBF LT3758AIMSE#TRPBF LTGGK 10-Lead (3mm × 3mm) Plastic MSOP –40°C to 125°C LT3758AHMSE#PBF LT3758AHMSE#TRPBF LTGGK 10-Lead (3mm × 3mm) Plastic MSOP –40°C to 150°C LT3758AMPMSE#PBF LT3758AMPMSE#TRPBF LTGGK 10-Lead (3mm × 3mm) Plastic MSOP –55°C to 150°C Contact the factory for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Tape and reel specifications. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. Rev F 2 For more information www.analog.com Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Applications Related Parts Typical Applications Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
