Datasheet LT3757, LT3757A (Analog Devices) - 2
Description | Boost, Flyback, SEPIC and Inverting Controller |
Pages / Page | 38 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION … |
Revision | F |
File Format / Size | PDF / 1.3 Mb |
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
LT3757/LT3757A
VIN, SHDN/UVLO (Note 6) ...40V Operating Temperature Range (Notes 2, 8) INTVCC ..VIN + 0.3V, 20V LT3757E/LT3757AE.. –40°C to 125°C GATE .. INTVCC + 0.3V LT3757I/LT3757AI ... –40°C to 125°C SYNC ..8V LT3757H/LT3757AH ... –40°C to 150°C VC, SS ...3V LT3757MP/LT3757AMP ... –55°C to 150°C RT ..1.5V Storage Temperature Range SENSE ..±0.3V DFN .. –65°C to 125°C FBX ... –6V to 6V MSOP .. –65°C to 150°C Lead Temperature (Soldering, 10 sec) MSOP ...300°C
PIN CONFIGURATION
TOP VIEW TOP VIEW VC 1 10 VIN VC 1 10 VIN FBX 2 9 SHDN/UVLO FBX 2 9 SHDN/UVLO SS 3 11 8 INTVCC SS 3 11 8 INTVCC RT 4 7 GATE RT 4 7 GATE SYNC 5 6 SENSE SYNC 5 6 SENSE MSE PACKAGE 10-LEAD PLASTIC MSOP DD PACKAGE 10-LEAD (3mm × 3mm) PLASTIC DFN TJMAX = 150°C, θJA = 40°C/W EXPOSED PAD (PIN 11) IS GND, MUST BE SOLDERED TO PCB TJMAX = 125°C, θJA = 43°C/W EXPOSED PAD (PIN 11) IS GND, MUST BE SOLDERED TO PCB
LT3757EDD#PBF LT3757EDD#TRPBF LDYW 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3757IDD#PBF LT3757IDD#TRPBF LDYW 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3757EMSE#PBF LT3757EMSE#TRPBF LTDYX 10-Lead (3mm × 3mm) Plastic MSOP –40°C to 125°C LT3757IMSE#PBF LT3757IMSE#TRPBF LTDYX 10-Lead (3mm × 3mm) Plastic MSOP –40°C to 125°C LT3757HMSE#PBF LT3757HMSE#TRPBF LTDYX 10-Lead (3mm × 3mm) Plastic MSOP –40°C to 150°C LT3757MPMSE#PBF LT3757MPMSE#TRPBF LTDYX 10-Lead (3mm × 3mm) Plastic MSOP –55°C to 150°C LT3757AEDD#PBF LT3757AEDD#TRPBF LGGR 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3757AIDD#PBF LT3757AIDD#TRPBF LGGR 10-Lead (3mm × 3mm) Plastic DFN –40°C to 125°C LT3757AEMSE#PBF LT3757AEMSE#TRPBF LTGGM 10-Lead (3mm × 3mm) Plastic MSOP –40°C to 125°C LT3757AIMSE#PBF LT3757AIMSE#TRPBF LTGGM 10-Lead (3mm × 3mm) Plastic MSOP –40°C to 125°C LT3757AHMSE#PBF LT3757AHMSE#TRPBF LTGGM 10-Lead (3mm × 3mm) Plastic MSOP –40°C to 150°C LT3757AMPMSE#PBF LT3757AMPMSE#TRPBF LTGGM 10-Lead (3mm × 3mm) Plastic MSOP –55°C to 150°C Contact the factory for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Tape and reel specifications. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. Rev. F 2 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
