Datasheet LTC4126 (Analog Devices) - 4
Description7.5mA Wireless Li-Ion Charger with 1.2V Step-Down DC/DC Converter
Pages / Page22 / 4 — ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply …
File Format / SizePDF / 2.3 Mb
ELECTRICAL CHARACTERISTICS The. denotes the specifications which apply over the specified operating
ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the specified operating
link to page 11 link to page 10 LTC4126
denotes the specifications which apply over the specified operating junction temperature range, otherwise specifications are at TA = 25°C (Notes 2, 3). VACIN = VCC = 5V, VBAT = 3.8V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Pushbutton Pin (PBEN)
VIL Logic Low Input Voltage l 0.4 V VIH Logic High Input Voltage l 1.1 V RPU Pull-up Resistance to BAT VPBEN < VIL 4 MΩ IIH Logic High Input Leakage VPBEN = VBAT 0 0.1 μA tDBL Debounce Time Low 348 425 503 ms tDBH Debounce Time High 23 43 63 ms
EN, VSEL Pins
VIL Logic Low Input Voltage l 0.4 V VIH Logic High Input Voltage l 1.1 V IIL Logic Low Input Leakage 0 1 μA IIH Logic High Input Leakage 0 1 μA
Logic Output Pins (STAT1, STAT2, ACPR)
VOL Logic Low Output Voltage 100μA into Pin 0.2 V VOH Logic High Output Voltage 25μA out of Pin VOUT – 0.2V V
Open Drain Output (CHRG)
Pin Leakage Current VCHRG = 5V 0 0.5 μA Pin Pull-Down Current VCHRG = 400mV 200 300 450 μA
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings characterization and correlation with statistical process controls. The may cause permanent damage to the device. Exposure to any Absolute junction temperature (TJ in °C) is calculated from the ambient temperature Maximum Rating condition for extended periods may affect device (TA, in °C) and power dissipation (PD, in watts) according to the formula: reliability and lifetime. TJ = TA + (PD • θJA),
Note 2:
All currents into pins are positive; all voltages are referenced to where the package thermal impedance θJA = 92°C/W). GND unless otherwise noted. Note that the maximum ambient temperature consistent with these
Note 3:
The LTC4126E is tested under conditions such that T specifications is determined by specific operating conditions in J ≈ TA. The LTC4126E is guaranteed to meet performance specifications from conjunction with board layout, the rated package thermal resistance, and 0°C to 85°C junction temperature. Specifications over the –20°C to other environmental factors. 85°C operating junction temperature range are assured by design,
Note 4:
See DC/DC Converter in Operation section. Rev. 0 4 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Electrical Characteristics Pin Configuration Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Typical Application Related Parts
