Datasheet LTC6908-1, LTC6908-2 (Analog Devices) - 5
Description | Resistor Set SOT-23 Oscillator with Spread Spectrum Modulation |
Pages / Page | 16 / 5 — TYPICAL PERFORMANCE CHARACTERISTICS. Output Resistance vs Supply. Output … |
Revision | B |
File Format / Size | PDF / 582 Kb |
TYPICAL PERFORMANCE CHARACTERISTICS. Output Resistance vs Supply. Output Operating at 5MHz,. Output Operating at 10MHz,
LTC6908-1/LTC6908-2
TYPICAL PERFORMANCE CHARACTERISTICS Output Resistance vs Supply Output Operating at 5MHz, Output Operating at 10MHz, Voltage V+ = 3V V+ = 5V
500 TA = 25°C 450 ) 400 Ω OUTPUT SOURCING CURRENT 350 (1V/DIV) (1V/DIV) 300 250 V OUT V OUT 200 150 OUTPUT SINKING CURRENT 690812 G08 690812 G09 OUTPUT RESISTANCE ( 80ns/DIV 40ns/DIV 100 50 02.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0 SUPPLY VOLTAGE (V) 690812 G07
Output Frequency Spectrum with Output Frequency Spectrum with SSFM Enabled and Disabled SSFM Enabled and Disabled
20dBm 20dBm RES BW = 220Hz RES BW = 9kHz SSFM ENABLED SSFM ENABLED (N = 16) (N = 16) 10dB/DIV 10dB/DIV SSFM DISABLED SSFM DISABLED –80dBm –80dBm 690812 G10 150kHz 690812 G11 5MHz FREQUENCY (7.5kHz/DIV) FREQUENCY (250kHz/DIV) Rev B For more information www.analog.com 5 Document Outline Features Applications Description Absolute Maximum Ratings Electrical Characteristics Pin Functions Operation Applications Information Typical Applications Package Description Typical Application
