Datasheet 2N3019, 2N3019S, 2N3700 (ON Semiconductor) - 2
ManufacturerON Semiconductor
DescriptionNPN Silicon Low Power Transistors
Pages / Page4 / 2 — 2N3019, 2N3019S, 2N3700. ELECTRICAL CHARACTERISTICS. Characteristic. …
Revision2
File Format / SizePDF / 110 Kb
2N3019, 2N3019S, 2N3700. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Min. Max. Unit. OFF CHARACTERISTICS. ON CHARACTERISTICS
2N3019, 2N3019S, 2N3700 ELECTRICAL CHARACTERISTICS Characteristic Symbol Min Max Unit OFF CHARACTERISTICS ON CHARACTERISTICS
link to page 2
(TA = 25°C unless otherwise noted)
Collector−Emitter Breakdown Voltage V(BR)CEO Vdc (IC = 30 mAdc) 80 − Emitter−Base Cutoff Current IEBO (VEB = 5.0 Vdc) − 10 nAdc (VEB = 7.0 Vdc) − 10 mAdc Collector−Emitter Cutoff Current ICEO (VCE = 90 Vdc) − 10 nAdc Collector−Base Cutoff Current ICBO (VCB = 140 Vdc) − 10 mAdc
ON CHARACTERISTICS
(Note 1) DC Current Gain hFE − (IC = 0.1 mAdc, VCE = 10 Vdc) 50 300 (IC = 10 mAdc, VCE = 10 Vdc) 90 − (IC = 150 mAdc, VCE = 10 Vdc) 100 300 (IC = 500 mAdc, VCE = 10 Vdc) 50 300 (IC = 1.0 Adc, VCE = 10 Vdc) 15 − Collector−Emitter Saturation Voltage VCE(sat) Vdc (IC = 150 mAdc, IB = 15 mAdc) − 0.2 (IC = 500 mAdc, IB = 50 mAdc) − 0.5 Base −Emitter Saturation Voltage VBE(sat) Vdc (IC = 150 mAdc, IB = 15 mAdc) − 1.1
SMALL−SIGNAL CHARACTERISTICS
Magnitude of Small−Signal Current Gain |hfe| − (IC = 50 mAdc, VCE = 10 Vdc, f = 20 MHz) 5.0 20 Small−Signal Current Gain hfe − (IC = 1.0 mAdc, VCE = 5 Vdc, f = 1 kHz) 80 400 Output Capacitance Cobo pF (VCB = 10 Vdc, IE = 0, 100 kHz ≤ f ≤ 1.0 MHz) − 12 Input Capacitance Cibo pF (VEB = 0.5 Vdc, IC = 0, 100 kHz ≤ f ≤ 1.0 MHz) − 60 Noise Figure NF dB (VCE = 10 Vdc, IC = 100 mAdc, Rg = 1 kW, PBW = 200 Hz) − 4.0 Collector−Base Time Constant r’b,CC ps (VCB = 10 Vdc, IC = 10 mAdc, f = 79.8 MHz) − 400
SWITCHING CHARACTERISTICS
Pulse Response ton + toff ns (Reference Figure in MIL−PRF−19500/391) − 30 1. Pulse Test: Pulse Width = 300 ms, Duty Cycle ≤ 2.0%.
http://onsemi.com 2
