Datasheet 2N4033 (STMicroelectronics) - 2
DescriptionSmall Signal PNP Transistor
Pages / Page6 / 2 — 2N4033. THERMAL DATA. ELECTRICAL CHARACTERISTICS. Symbol. Parameter. Test …
File Format / SizePDF / 502 Kb
2N4033. THERMAL DATA. ELECTRICAL CHARACTERISTICS. Symbol. Parameter. Test Conditions. Min. Typ. Max. Unit
2N4033 THERMAL DATA ELECTRICAL CHARACTERISTICS Symbol Parameter Test Conditions Min Typ Max Unit
2N4033 THERMAL DATA
R o thj-case Thermal Resistance Junction-Case Max 37.5 C/W R o thj-amb Thermal Resistance Junction-Ambient Max 187.5 C/W
(Tcase = 25 oC unless otherwise specified)
Symbol Parameter Test Conditions Min. Typ. Max. Unit
ICBO Collector Cut-off VCE = -60 V -50 nA Current (IE = 0) VCE = -60 V TC = 150 oC -50 µA V(BR)CBO Collector-Base IC = -10 µA -80 V Breakdown Voltage (IE = 0) V(BR)CEO∗ Collector-Emitter IC = -10 mA -80 V Breakdown Voltage (IB = 0) V(BR)EBO Emitter-Base IE = -10 µA -5 V Breakdown Voltage (IC = 0) VCE(sat)∗ Collector-Emitter IC = -150 mA IB = -15 mA -0.15 V Saturation Voltage IC = -500 mA IB = -50 mA -0.5 V VBE(sat)∗ Base-Emitter IC = -150 mA IB = -15 mA -0.9 V Saturation Voltage IC = -500 mA IB = -50 mA -1.1 V hFE∗ DC Current Gain IC = -100 µA VCE = -5 V 75 IC = -100 mA VCE = -5 V 100 300 IC = -500 mA VCE = -5 V 70 IC = -1 A VCE = -5 V 25 IC = -100 mA VCE = -5 V Tamb = -55 oC 40 fT Transition Frequency IC = -50 mA VCE = -10 V 150 500 MHz f = 100 MHz CEBO Emitter-Base IE = 0 VEB = -0.5 V f = 1MHz 110 pF Capacitance CCBO Collector-Base IC = 0 VCB = -10 V f = 1MHz 20 pF Capacitance ts∗∗ Storage Time IC = -500 mA VCC = -30 V 350 ns IB1 = -IB2 = -50 mA tf∗∗ Fall Time IC = -500 mA VCC = -30 V 50 ns IB1 = -IB2 = -50 mA ton∗∗ Turn-on Time IC = -500 mA VCC = -30 V 100 ns IB1 = -IB2 = -50 mA * Pulsed: Pulse duration = 300 µs, duty cycle ≤ 1 % ∗∗ See Test Circuit Obsolete Product(s) - Obsolete Product(s) 2/6
