Datasheet 1N4001, 1N4002, 1N4003, 1N4004, 1N4005, 1N4006, 1N4007 (Vishay) - 2
ManufacturerVishay
DescriptionGeneral Purpose Plastic Rectifier
Pages / Page5 / 2 — 1N4001 thru 1N4007. ELECTRICAL CHARACTERISTICS. PARAMETER TEST
File Format / SizePDF / 83 Kb
1N4001 thru 1N4007 ELECTRICAL CHARACTERISTICS PARAMETER TEST
1N4001 thru 1N4007
Vishay General Semiconductor
(TA = 25 °C unless otherwise noted)
PARAMETER TEST CONDITIONS SYMBOL 1N4001 1N4002 1N4003 1N4004 1N4005 1N4006 1N4007 UNIT
Maximum instantaneous 1.0 A V forward voltage F 1.1 V Maximum DC reverse current TA = 25 °C 5.0 I μA at rated DC blocking voltage R TA = 125 °C 50 Typical junction capacitance 4.0 V, 1 MHz CJ 15 pF
THERMAL CHARACTERISTICS
PARAMETER SYMBOL 1N4001 1N4002 1N4003 1N4004 1N4005 1N4006 1N4007 UNIT
RJA (1) 50 Typical thermal resistance °C/W RJL (1) 25
Note
(1) Thermal resistance from junction to ambient at 0.375" (9.5 mm) lead length, PCB mounted
ORDERING INFORMATION
(Example)
PREFERRED P/N UNIT WEIGHT (g) PREFERRED PACKAGE CODE BASE QUANTITY DELIVERY MODE
1N4004-E3/54 0.33 54 5500 13" diameter paper tape and reel 1N4004-E3/73 0.33 73 3000 Ammo pack packaging
RATINGS AND CHARACTERISTICS CURVES
(TA = 25 °C unless otherwise noted) 1.0 30 60 Hz Resistive T = 55 °C A or Inductive Load 8.3 ms Single Half Sine-Wave ent (A) 0.8 25 ent (A) 0.2" x 0.2" 0.6 (5.0 mm x 5.0 mm) 20 ge Curr Copper Pads ur S d Rectified Curr d 0.4 15 0.2 10 erage Forwar Peak Forwar v 0.375" (9.5 mm) Lead Length A 0 5 0 25 50 75 100 125 150 175 1 10 100 Junction Temperature (°C) Number of Cycles at 60 Hz Fig. 1 - Forward Current Derating Curve Fig. 2 - Maximum Non-repetitive Peak Forward Surge Current www.vishay.com For technical questions within your region, please contact one of the following: Document Number: 88503 2 DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com Revision: 23-Feb-11
