Datasheet MP28300 (Monolithic Power Systems)
Manufacturer | Monolithic Power Systems |
Description | 300mA, 5.5V, 500nA, Ultra-Low Iq, Synchronous, Step-Down Converter plus 100mA LDO in 2x2 QFN |
Pages / Page | 20 / 1 — MP28300. Ultra-Low 500nA Iq, Wide Input 2V-5.5V,. 300mA Step-Down … |
File Format / Size | PDF / 657 Kb |
MP28300. Ultra-Low 500nA Iq, Wide Input 2V-5.5V,. 300mA Step-Down Regulator Plus300nA Iq,
MP28300 Ultra-Low 500nA Iq, Wide Input 2V-5.5V, 300mA Step-Down Regulator Plus300nA Iq, 2V-5.5V Input, 100mA LDO in 2x2 QFN The Future of Analog IC Technology DESCRIPTION FEATURES
The MP28300 is a monolithic power- 300mA Buck Switcher management unit containing 300mA, high- o Ultra-Low Iq: 500nA efficiency, step-down, switching converters and o Wide 2.0V to 5.5V Operating Input a 100mA LDO regulator. The nanoamp Range quiescent current provides extremely high o 7 Selectable Output Voltages efficiency when the load current is down in the o Up to 300mA Output Current µA range. With minimum input voltage as low o 1.5MHz Switching Frequency in as 2V, the MP28300 allows the system to Continuous Conduction Mode (CCM) operate directly from the battery. o 100% Duty Cycle in Dropout The constant-on-time control scheme provides o 0.25Ω and 0.25Ω Internal Power fast transient response, high light-load MOSFET Switches efficiency, and requires minimal capacitance. o Cycle-by-Cycle Over-Current Protection The regulation can be made tight by integrating (OCP) an error amplifier to correct the output voltage. o Short-Circuit Protection (SCP) with Hiccup Mode An 100mA LDO regulator provides easy system 100mA LDO configuration with clean output voltage. o Ultra-Low Iq: 300nA The CTRL pins control the on/off and output o 2.0V to 5.5V Operating Input Range voltage selection functions. o 3 Selectable Output Voltages o Over-Temperature Protection (OTP) Fault protection features include under-voltage Available in a QFN-12 (2mmx2mm) lockout (UVLO), over-current protection (OCP), Package and thermal shutdown.
The MP28300 requires a minimal number of readily available, standard, external Wearables components and is available in a small QFN-12 IOT (2mmx2mm) package. Portable Instruments Battery-Powered Devices All MPS parts are lead-free, halogen-free, and adhere to the RoHS directive. For MPS green status, please visit the MPS website under Quality Assurance. “MPS” and “The Future of Analog IC Technology” are registered trademarks of Monolithic Power Systems, Inc.
TYPICAL APPLICATION Efficiency vs.Load Current
VOUT=1.8V 100 90 80 V 70 IN=2V VIN=2.5V 60 VIN=3.0V V 50 IN=3.6V VIN=4.2V 40 VIN=5.0V 30 0.001 0.01 0.1 1 10 100 1000 IOUT (mA) MP28300 Rev.1.1 www.MonolithicPower.com 1 6/12/2019 MPS Proprietary Information. Patent Protected. Unauthorized Photocopy and Duplication Prohibited. © 2019 MPS. All Rights Reserved.
