Preliminary Datasheet P9415 (IDT) - 3
Manufacturer | IDT |
Description | Medium Power Wireless Transmitter/Receiver (TRx) |
Pages / Page | 26 / 3 — Table 1. Pin Descriptions. Type. Description |
Revision | 20190829 |
File Format / Size | PDF / 1.3 Mb |
P9415 Preliminary Datasheet
Number Name
Type Description
A1 COM1 O High-voltage open-drain modulation FET. Connect a capacitor from AC1 to COM1. A2 GP1 I/O General Purpose Push-Pull I/O, referenced to LDO1P8. May be floating if not used. A3 OD0 I/O Clock for I2C Serial Interface with AP (SCL). Connect a pull-up resistor to the system I/O supply. A4 OD3 I/O General Purpose Open Drain I/O, referenced to LDO1P8. May be floating if not used. A5 GP4 I/O General Purpose Push-Pull I/O, referenced to LDO1P8. May be floating if not used. A6 COM2 O High-voltage open-drain modulation FET. Connect a capacitor from AC2 to COM2. B1 CMA O High-voltage open-drain modulation FET. Connect a capacitor from AC1 to CMA. B2 GP0 I/O General Purpose Push-Pull I/O, referenced to LDO1P8. May be floating if not used. B3 OD1 I/O Data for I2C Serial Interface with AP (SDA). Connect a pull-up resistor to the system I/O supply. B4 OD4 I/O General Purpose Open Drain I/O, referenced to LDO1P8. May be floating if not used. B6 CMB O High-voltage open-drain modulation FET. Connect a capacitor from AC2 to CMB. C3 OD2 I/O General Purpose Open Drain I/O, referenced to LDO1P8. May be floating if not used. ECLAMP_D Push-Pull output driver for External Power Clamp FET gate control (Connect a resistor from Vrect to the C4 RV O external FET to GND). May be floating if not used. C5 GP2 I/O General Purpose Push-Pull I/O, referenced to LDO1P8. May be floating if not used. D1 LDO5P0 O Internal 5V LDO for chip power only (always On when Vrect is powered). Connect a capacitor to ground. D2 GP5 I/O General Purpose Push-Pull I/O, referenced to LDO1P8. May be floating if not used. D3 PCLAMP I High voltage open drain input for linear clamping during OVP events. Connect a resistor from this pin to VRECT for >5W operation. Short directly to VRECT for 5W or lower power applications. D4 GP3 I/O General Purpose Push-Pull I/O, referenced to LDO1P8. May be floating if not used. D5 GP6 I/O General Purpose Push-Pull I/O, referenced to LDO1P8. May be floating if not used. © 2019 IDT A Renesas Company. 3 Revision 0.8 August 29, 2019
