Datasheet ADXL1003 (Analog Devices) - 6
Description | Low Noise, Wide Bandwidth, MEMS Accelerometer |
Pages / Page | 14 / 6 — ADXL1003. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 0.8. 0.7. 0.6. … |
File Format / Size | PDF / 518 Kb |
ADXL1003. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 0.8. 0.7. 0.6. E C. L 0.5. RE E. PO 0.4. )/RE. 0.3. 0.2. PER. 0.1. 100. 10k. 100k. 10
ADXL1003 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS 12 0.8 0.7 10 )) E N (g 0.6 IO UD E C T 8 IT A L N L 0.5 P RE E PU AM F D 6 PO 0.4 E F )/RE IZ O L (g T A T 0.3 4 EN RM PU C T NO U 0.2 (O PER 2 0.1 0 0 100 1k 10k 100k 5 6 7 8 9 0 1 2 3 4 5 6 7
04 0
9. 9. 9. 9. 9.
07 6-
10. 10. 10. 10. 10. 10. 10. 10.
0
FREQUENCY (Hz)
59 96- 16
SENSITIVITY (mV/g )
165 Figure 4. Frequency Response, High Frequency (>5 kHz) Vibration Response; Figure 7. Sensitivity Distribution at 25°C a Laser Vibrometer Controller Referencing the ADXL1003 Package Used for Accuracy
10000 100000 DUT1 DUT2 ) 10000 1000 /√Hz g ) Y (µ /√Hz IT g S 1000 N (µ E 100 D L A R ISE PSD T 100 O N EC 10 SP R E W 10 PO 1 100 1k 10k 100k
008
1
05 96-
0.01 0.1 1 10
06-
FREQUENCY (Hz)
65 1
FREQUENCY (Hz)
659 1 Figure 5. Noise Power Spectral Density (PSD) Below 10 Hz vs. Frequency Figure 8. Noise PSD Above 100 Hz
5 1.0 ) 0.8 E AL 3 C cale) 0.6 S -S L ll 0.4 UL Fu F 1 of 0.2 (% (% E OR 0 ANG R –1 CH ER –0.2 Y Y T IT –0.4 IV IVI IT IT S S –3 –0.6 N E S SEN –0.8 –5 –1.0
9
–50 –30 –10 10 30 50 70 90 110 130 150
006
10 30 50 70 90 110 130 150 170 190
-00 6- 96
TEMPERATURE (°C) INPUT ACCELERATION (g )
1659 165 Figure 6. Sensitivity vs. Temperature Figure 9. Sensitivity Nonlinearity vs. Input Acceleration Rev. 0 | Page 6 of 14 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE RECOMMENDED SOLDERING PROFILE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION MECHANICAL DEVICE OPERATION OPERATING MODES Measure Mode Standby Mode BANDWIDTH APPLICATIONS INFORMATION APPLICATION CIRCUIT ON DEMAND SELF TEST RATIOMETRIC OUTPUT VOLTAGE INTERFACING ANALOG OUTPUT BELOW 10 kHz INTERFACING ANALOG OUTPUT BEYOND 10 kHz OVERRANGE MECHANICAL CONSIDERATIONS FOR MOUNTING LAYOUT AND DESIGN RECOMMENDATIONS OUTLINE DIMENSIONS ORDERING GUIDE
